Results 1 to 12 of 12
Thread: staling vr 5ltr calais
    tailhappy vn is offline I H8 FORDS
    vn 5ltr auto vr v6 5spd vt v6 wagon
    Mar 2009
    sydney
    Question staling vr 5ltr calais
    gday guys and girls new 2 the forum have a 5ltr calais hsv enhanced and wen is at running temp and put in reverse or drive she stalls any suggestions would be appreciated cheers
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Probably the ignition module or the coil - both can give trouble when hot. Here is a good link about someone with your same problem. Also try a search on this forum - just put "5 litre stalls" in the search machine and presto:
    VR Clubsport stalls
    And welcome to the forum.
    vr ute
    Mar 2009
    i recently had this problem. i changed the coil and its all good.
    i wouldnt put the coil in the original spot. move it to the inner guard and it'll be better.
    i couldnt get the original coil out so i broke the wires off.the brown wire is the ground or negative and the red the positive
    good luck
    Vr Executive 3.8
    Dec 2008
    Just a thought, my Vr V6 was doing this really badly recently, I couldn't stop the car in drive at idle without it stalling let alone changing directions.
    The alternator had packed it in and I had put a new alternator in and the car ran like an absolute pig, stalling/ misfiring, the gearbox dropped first gear and went into limp mode, checked it out and the new alternator was playing up, once I changed the alternator again she runs smooth as without any problems.
    Most probably isn't this but thought i'd let you know just in case.
    James_yo7's Avatar
    James_yo7 is offline Barbitaboopey?
    2008 LUX minitruck
    Feb 2007
    Melbourne, Vic
    When you get this problem check the usual things like alternator, fuel filter, fuel pump
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Geez it must be crappy idle day
    5ltr V8 In VS Caprice Won't Idle - ??????
    Check your vacuum hoses too although that would happen all the time not just when hot, also check things like where it idles when cold and where when at norm temp etc, you may be able to figure out that its something simple.
    Mar 2009
    sydney
    cheers i will check coil an ignition switch i must ask is their a way to reply to all my msgs at once or must this be done one by one.
    Mar 2009
    sydney
    cheers mate yes i would imagine it would get hot and suffocate were it is not a great spot..
    Mar 2009
    sydney
    Mar 2009
    sydney
    Mar 2009
    sydney
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Does it stall with aircon on and off?
  1. old VK calais 5ltr
    By AndyVKSSA in forum VB - VC - VH - VK
    Last Post: 02-02-2009, 10:33 AM
  2. F/S - VN Calais 5ltr (SA)
    By Dan355 in forum Vehicles For Sale
    Last Post: 03-04-2007, 10:24 PM
  3. my vn is staling
    By Dave_0101 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2007, 05:13 PM
  4. 5ltr vt calais
    By kniever in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-02-2007, 06:08 PM
