Results 1 to 2 of 2
Thread: code 46
    VS commodore v6 1996
    Mar 2009
    Unhappy code 46
    Code 46 - No Reference Signals while cranking
    results in my car sometimes not starting sometimes it cranks but doesn't tick over help please?
    new key batteries???
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Code 46 refers to either a faulty crank angle sensor or a faulty DFI....so for some reason or other when you crank the car over the ECU is not getting a signal which tells it to start firing the plugs. First thing I'd do is check all the wiring to the DFI which is under the coil packs - sometimes water can get in there and cause corrosion. If the car has been stalling when hot of late then I'd replace the CAS.
    If the remote on the key works the battery will be OK.
    Good Luck.
  1. Code 72 - Vehicle Speed Sensor (VSS) and Code 73 - Pressure Control Solenoid Current
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2009, 04:39 PM
  2. 92 code
    By glowworm in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2008, 03:54 PM
  3. Code 13
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-01-2008, 10:59 PM
  4. Code 76
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2006, 10:52 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
