Results 1 to 18 of 18
Thread: water for battery
    vr statesman 5.0 + vs exec s2 auto
    Mar 2006
    central coast, nsw
    Lightbulb water for battery
    dunno if this is the right section , but can anyone tell me if its ok or not to use filtered tap or town water to top up our car batteries. yes, i know i`m a cheapskate but if it saves buying distilled water , why not. thanks if you can help.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    its best to use distilled, but if none is available, then filtered tap water is fine.
    vr berlina
    Aug 2008
    yeah filtered is alright, some mechanics will use pura tap to fill up batteries, but best always if u can to use distilled
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Distilled water is cheaper then a new battery, or doing damage to your car.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Filtered water does not have the impurities that damage the battery cells removed....you need either distilled or de-ionised water. You can gather rain water or boil the kettle and condense the steam. Bore water is worst of all for batteries and lots of places now have bore water mixed with dam water like Toowoomba.
    the collector is offline the collector
    rodeo dual cab
    Mar 2009
    adelaide
    Default bty
    distilled water isnt expensive
    calling your mate for a jumpstart at 2am will cost you at least a carton,and a tow truck even more.
    batteries are only reliable for a couple of years anyway imo
    cheers
    Mar 2006
    central coast, nsw
    well i think it will be safer if i keep useing distilled water . i just wanted to know if filtered water would remove the harmful minerals. but after reading your replies i wont use filtered water. cheers 2 you all.
    96 VS II Acclaim
    Dec 2007
    Just use tap water, I've used tap water for many,many years without any problems whatsoever.
    VT
    Apr 2005
    QLD
    Demineralised water is the go.
    If you're gonna pour filtered tap water in there, you might as well just top it up with the garden hose.
    OzJD's Avatar
    OzJD is offline Not your average Joe.
    VR6 S1 & VR6 S2
    Feb 2009
    Parramatta, NSW
    Yeh I know people who've used normal tap water (from Warragamba damn) and had no issues in years (I have more issues than they do )
    Current mods/repairs:
    Power Windows Installation (70% Complete)
    Current Issue(s)
    N/A
    My Holden doesn't leak, It's just marking it's territory!
    Quote Originally Posted by 88GreenVN View Post
    Missing teeth from the diff is terminal as in diff no worky. Crunch crunch bank snap and then STOP.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Tap water contains dissolved impurities, so as the water in the battery evaporates the solids do not and sink to the bottom forming a sediment. As this sediment builds up it reduces the surface area of the plate and reduces the effectiveness of the battery, shortening it's life.
    It would be OK to use tap water occasionally but I wouldn't use all the time.
    Having said that, it also depends on the quality of the tap water. IMO, filtered tap water would be perfectly fine.
    Visit my Facebook page
    VX SS M6
    Jun 2005
    how about boiled water from the kettle that's been boiled a couple of times? is that ok?
    Holden VS Executive Sedan
    Apr 2009
    Blacktown
    god distilled water ot that much, god you can even distill your own water
    Tit-Tit-Titian™
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by VSIIBerlinaL67 View Post
    No different than tap water because the dissolved solids don't evaporate.
  15. #15
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    I wouldn't be shortening the life of a hundred dollar battery, just to save three dollars on four litres of distilled water
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
  16. #16
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    if you need 4ltrs of distilled water to top your battery up, i well and truelly think ur battery is cactus
  17. #17
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    Quote Originally Posted by ephect View Post
    Just bought a four litre bottle for my radiator.
    The hall of fame:
    ಠ_ಠ
  18. #18
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I know this thread is answered, but i'll just add i have been using tap water in my batteries for years. Not that they need topping up very often at all, maybe once in their life if at all. Some ive had dont even make it to the first top up. Yes its bad, but a once off top up of town water wont hurt it, especially if its filtered. But as above if you know your town water has lots of minerals in it then it may be best to avoid it.
    BTW rain water is not that good it catches many minerals on its way down, especially if your like me and live next to the steel works, its even worse if your collecting it off the ground or off your roof.
    Reaper
  1. [VIC] Misc parts - gauge, steering wheel, speakers, battery cover, battery box
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 06-05-2009, 06:32 PM
  2. battery
    By ImALittleTeapot! in forum Car Audio
    Last Post: 18-01-2009, 09:57 PM
  3. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  4. battery
    By me_011 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2006, 11:55 AM
  5. car covers . water proof vented vs water resitant non vented
    By justbad4you in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-10-2005, 01:20 PM
