Results 1 to 4 of 4
Thread: Double-Din My install and mods...CHECK IT OUT...
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    Exclamation Double-Din My install and mods...CHECK IT OUT...
    ok...so me and my mechanic (and mate) got together and did this.......i called about 10 installation places to find out who could do a Double-Din in a VR-VS....but no 1 had ever done 1...
    so we ripped the dash apart and took a look where we could mount it....
    we decided to take out the two middle air vents and "Re-Design" the Heater box.......there is two pipes that run from the heater box that bypass's the two airvents we took out...they are fabricated so no air escapes...but goes straight to the door vents....im quite happy with it....
    but if i had my time over wouldnt have done it.....
    Let me know what you think
    also the hazard lights and aircon buttons etc....are being mounted where the old unit was... im also making the "coin area" bigger so i can get my hand in there and also put more/larger objects..... and need to install new heater\ temperature selector....mine was broken
    by te way....the sorrounding parts arent finished...they need to be fibreglassed so it all comes up to the unit and sit's flush so you cant see "metal"...
    Attached Thumbnails Attached Thumbnails Double-Din My install and mods...CHECK IT OUT...-p100309_18.50-03-.jpg   Double-Din My install and mods...CHECK IT OUT...-p100309_18.51.jpg
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i've seen a few double dins install like that, not to my taste, but it'll get there once its finished off.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Talking Use the statesman stereo surround
    Looks a bit messy at the moment but maybe you could use a Statesman center console as it has a storage compartment in between the double din and the old stereo spot for the airvents put a link to a statesman pic.
    photo gallery popup
    and maybe use the elec antenna, A/C buttons from VN/VP/VR/VS for your other buttons that you've removed.
    photo gallery popup
    would make it so atleast you could have air vents in the middle and it would look pretty neat, and once its finished if you do it rihgt it should look almost fatory!
    Disturbed_vegeta's Avatar
    Disturbed_vegeta is offline I'd Prefer To ROAR!
    Vs Statesman, Vr Senator 185I
    Dec 2005
    Burpengary
    what...why?
  1. is it possible to install a double din stereo into my vn
    By vnwagon91 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2011, 08:37 AM
  2. Airbag warning light after headers install and brake check??
    By Curtisb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2009, 12:07 AM
  3. double din install, aircon screen problems
    By 02DUBH in forum General
    Last Post: 03-01-2009, 04:39 PM
  4. double-din h/u install help
    By FORCED in forum Car Audio
    Last Post: 02-08-2008, 11:08 AM
  5. vxV6 mods,best mods to choose?help appreciated
    By benjamino in forum V6 Development And Modification
    Last Post: 11-06-2008, 09:51 AM
