Results 1 to 7 of 7
Thread: increased fuel consupmtion
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    Default increased fuel consupmtion
    I've recently got my car back from the panel beater and gthe last few days it seems to have used a lot more fuel than normal, the car ran out of fuel while it was there I don't know if this is of any relevance also I've noticed it misfiring the last couple of days again I don't know it ifs of any relevance any advice would greatly apprecitated
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If it ran out of fuel it probably sucked up all the dregs at the bottom of the tank - the filter should have removed this junk but some always seems to get thru. I'd throw a can on injector cleaner thru the system and also check for any logged codes:
    Checking error codes VR/VS (Revised)
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i would be first checking ur error codes to see if its logged any codes that could point us in the right direction. could have gotten shit from the bottom of the tank thats clogged up the fuel filter.
    there has been a few threads on this that a quick search should bring em up.
    EDIT: hako bet me to it by a minute
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    check this link out for more info on fuel consumption How low can you go? (fuel economy)
    another one: Too lean on one bank
    Feb 2009
    longford, victoria
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    check the bottom of hako's post #2 he included the link!
    Feb 2009
    longford, victoria
    Sorry half asleep yeah I gotta get me some paper clips
  1. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  2. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  3. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  4. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  5. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
