Results 1 to 6 of 6
Thread: fuel problem vr 5lt
    VR 5LTR
    Mar 2009
    Bay of plenty
    Default fuel problem vr 5lt
    hi, i have a problem with my vr 5ltr, when driving it normally in straight lines and going around corners at normal rev,s etc it is fine but if i give it a heap of pedal going around a corner it cuts out has done it a couple of times and yesterday when it did it, it actually cut out completely and no power, started it back up sweet as and drove sweet as just does it going round corners then giving a boot full, any suggestions would be helpful,
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    check these things
    Fuel
    Spark
    if you have no faults there,
    compression.
    SIR LS1
    the two ton go kart
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    How much fuel do you have in the tank?
    Mine was cutting out when going around RH corners with less than a 1/4 tank of fuel. Fixed it by replacing the fuel pump. All ok now.
    muttley383
    VR 5LTR
    Mar 2009
    Bay of plenty
    at the moment it only has a 1/4 of a tank of gas aswell, will fill it up and try that, if it doesn't do it will look at fuel pump cheers
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    thinking somthin to do with the swirl pot, and return line.
    Reaper
    VR 5LTR
    Mar 2009
    Bay of plenty
    may sound like a dumb question but where is the swirl pot, also is the coil mounted by the dizzy, if not where abouts
  1. fuel problem
    By prozak in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-08-2010, 09:12 PM
  2. fuel problem i think
    By rayv6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-06-2008, 07:22 PM
  3. fuel problem
    By vpssguy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-03-2007, 09:45 AM
  4. Fuel problem
    By SweetWagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2006, 03:18 PM
  5. Fuel Problem
    By Brenno85au in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-03-2005, 12:05 AM
