Results 1 to 6 of 6
Thread: Replacing gearbox and clutch VR
    VR V6 Ute Manual
    Dec 2005
    Default Replacing gearbox and clutch VR
    hey guys hopefully someone can help me explain whats going on with my car
    i just got a vr v6 manual ute
    the clutch i got in it is very hard to press down. its the way the car came when i bought it. a friend told me its probably a heavy clutch and its nothing to worry about. how can you tell the difference? to be honest the clutch does seem fine when driving but i think i have issues with the gearbox.
    sometimes, usually just after the car has been started when i change into first or second gear i hear a loud metal grinding like noise. im not sure if its coz i didnt press hard enough on the clutch or its the gearbox itself. and to change into second gear its not as smooth as changing into 3rd or 4th gear. how much would it be for a new gearbox or to rebuild one?
    cheers
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like either the clutch plate is on its last legs or it needs adjusting. Can't remember if you've got cable or hydraulic actuation but if cable it may need adjusting and if hydraulic it may need bleeding. There is also an adjustment for the clutch lever pivot. Usual cause of hard to shift gears is clutch not fully releasing...for the above reasons.
    Good Luck.
    VR V6 Ute Manual
    Dec 2005
    so if i bled or adjusted the clutch, it would probably make it easier to change gears? i failed to mention this but the clutch squeaks when i press down on it and again when releases. im positive now that its a heavy duty clutch also.
    its just ive noticed alot of clanking like sound coming from the gearbox when im changing gears. not loud but its there. another thing ive noticed is that the gearstick is starting to warmup quite a bit. and when i accelerate moderately to hard i can feel very warm air rush by my hand. specially in 4th gear. could a bad clutch be doing something bad to the gearbox?
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    The squeaking noise you can hear when you depress the clutch pedal is likely to be because the clutch pedal pivot shaft is dry, grease it up and it should sort that out. Being a vr, your gearbox will be a borgwarner T5 and therefore will be cable operated and as hako has said, it may just need adjusting. It is also possible that if this cable is well worn it could be contributing to how heavy the clutch feels and may need replacing. Also if you can feel alot of warmth coming up through around the gear stick id be guessing that the rubber boot that mounts around the shaft and to the floor has possibly been removed.
    1994 VR Commodore executive ute
    May 2012
    geelong, VIC
    iv also got a vr ute that has the same problem, but its some times tempermental to click into 1st and reverse, iv notice (which its only just started), when im driving in first, i go to 2nd, then i go back to first with out releasing the clutch, and it grinds like the clutch wasnt in, so i was thinking it could be slack in the cable, if so, how do i go about tightening it???
    VZ SS 6 SPEED MANUAL
    Apr 2007
    WA
    Have you checked your gear box oil level mate, could be low ???
    Or may need changing ??
  1. help replacing clutch
    By shaggy0001 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-07-2008, 10:14 PM
  2. VS Ute gearbox/clutch?
    By overgrown in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2008, 09:44 PM
  3. gearbox? clutch?
    By bassmansimon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-01-2007, 08:16 PM
  4. Replacing VT Clutch
    By Holden_ve in forum The Pub
    Last Post: 15-08-2005, 01:52 PM
  5. Replacing Your Clutch - VL RB20/30
    By jetspin_vn in forum Holden Commodore How-To's
    Last Post: 11-10-2004, 09:08 PM
