Results 1 to 9 of 9
Thread: How to remove inlet manifold on 5 litre
    VS II 5 ltr Berlina Wagon
    Apr 2004
    Default How to remove inlet manifold on 5 litre
    Ok I'm trying to replace the inlet manifold gaskets and have stripped everything down to the point where I am ready to remove the manifold, but there is bugger all room to get to the bolts (all 14 of them !) . Do you need to remove the fuel rail or is it a special tool that gets to the bolts ?
    Mmmmm V8
    faroogoo's Avatar
    faroogoo is offline SENTINEL
    GMH
    Nov 2006
    S.A
    Ratchet ring spanner might work...
    "If you're going through hell, keep going"
    Apr 2004
    Reckon it would work, but it's the retensioning that I worry about.
    Mmmmm V8
    eaton v8's Avatar
    eaton v8 is offline my little sleeper
    vz 6l auto 239cam 3.9diff
    Jun 2008
    gladstone qld
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    so you are suspecting its the inlet gasket then?
    No incontinance panties just yet
    Apr 2004
    Took the fuel rails off and presto all exposed so to speak. Yes Norti I think it is the gasket as it starts to weep there around the front drivers side corner where the inlet manifold mates with the block when you start the engine. It started about 2 weeks ago and ramped up prerrt quick where it makes a pool of coolant after a few minutes of running.
    Mmmmm V8
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    As you would know the thermostat housing is there too and it also sits right there where the gallery is. Its not just the O ring in the housing leaking and leaving a pool of coolant there. I had 2 new o rings in mine recently and they both leaked within a week. Went to holden and got a genuine one and its stopped pooling coolant there on the inlet manifold.
    Also tensioning the inlet manifold again. Start in the middle on the drivers side then go middle passenger side and work your way out on both sides.
    13 14
    9 10
    5 6
    1 2
    3 4
    7 8
    11 12
    Reaper
    Apr 2004
    Thanks VrWagz1. I'll have another carefull look at the thermostat housing, but I'm fairly confident that it is the gasket as it seems to be a common problem when the 5 litres are this old and with 220k's under its belt (when I said pooling I meant on the ground). Thanks for the bolt sequence as I was trying to find one as the Ellery's manually is vague in a lot of areas.
    Mmmmm V8
    VrWagz1's Avatar
    May 2008
    wollongong
    Just had a quick read of my manual, it says to do the bolts up twice bassically. Do them once in order with about 15nM, and then repeat the process again at about 38nM torque.
    Reaper
  1. l67 inlet manifold
    By Adrian in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2008, 12:46 PM
  2. vs inlet manifold
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2008, 12:49 AM
  3. inlet manifold
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 09:52 PM
  4. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
  5. wtb: inlet manifold for vh
    By white vn ss in forum Swap / Wanted to Buy / Trade
    Last Post: 12-03-2006, 12:47 PM
