Results 1 to 3 of 3
Thread: v6 belt tensionor removal
    vx ss
    Jan 2007
    Default v6 belt tensionor removal
    Hey all,
    My 95 vs ecotec V6 belt tensioner housing has cracked on the top where the spring sits against the housing. The pully is also whistling..... I was wondering if anyone knows how to get the housing off without taking the heater hoses off by undoing that screw in front of where the spring is located, can that part be changed instead of the whole housing????
    Thanks Kasie
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Pretty sure there is no easy way unfortunately. Don't leave it for too long as when it fails completely you will be stranded and need a tow home.
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    just out of interest how do you get those heater hoses out and back in from the housing, they are pressed in arn't they?
  1. EGR Belt VT
    By LAUREN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-05-2010, 11:56 AM
  2. help with air con belt
    By darin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-11-2008, 02:06 PM
  3. Which way does the belt go!!? HELP
    By timbra_88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2008, 07:10 PM
  4. Serpentine belt (Acc Belt)
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2007, 12:12 PM
  5. How goes the fan belt?
    By Stumped in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-08-2005, 10:48 AM
