Results 1 to 8 of 8
Thread: Replace Inlet Manifold Gasket and Valves
    VR Series II S-Pac 5spd
    Jul 2008
    Default Replace Inlet Manifold Gasket and Valves
    Hey guys i need to replace my inlet manifold gasket and the valve stem seals and was wondering what people reckon on prices of getting it done including parts and labour? I got quoted at ultratune around $1100 which to me is quite steep
    If anyone has any idea or could help it would be appreciated
    Thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you wanted to save about $1000 you could do it yourself. Alternatively you could live with the valve stem seals leaking a bit - this does not affect efficiency, just blows a puff of blue smoke on start-up. The inlet manifold gasket you could then replace with the aid of a Gregorys manual and the search facility on this forum. Is the gasket leaking coolant or oil?
    Jul 2008
    yeh its blowing out a bit of light smoke at start up and its losing coolant and oil its kind of weird for a while was losing oil and then both and now mainly just coolant
    i have a manual but heard its quite a big job and dont really want the car out of action for a while
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check the post I've put below - mumboman has some good advice there about costs. Re the blue smoke it's not a defect as long as it goes away after a few seconds....just a nuisance and shouldn't affect normal operations unless it gets really bad. Even then there are simple methods to replace them. The $1100 quote is very very steep...almost vertical.
    hot hot hot
    Good Luck.
    Jul 2008
    yeh its nothing serious but its been happening for a few months now and ive just kept letting it slide lol but thinkin i should probably do something about it soon
    Jul 2008
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Inlet manifold is a peice of cake. You could do it for under $80 and in one day if you had absolutely no idea what you were doing.
    eaton v8's Avatar
    eaton v8 is offline my little sleeper
    vz 6l auto 239cam 3.9diff
    Jun 2008
    gladstone qld
    Quote Originally Posted by maldotcom2 View Post
    ill second that its real easy
  1. Inlet Manifold (Gasket???)
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2012, 02:44 PM
  2. Inlet manifold gasket
    By gogoboygareth in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-11-2008, 07:02 PM
  3. inlet manifold gasket, change
    By hN! in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-11-2008, 04:20 PM
  4. Inlet Manifold Gasket. Common???
    Last Post: 14-09-2008, 05:13 PM
  5. inlet manifold gasket leak?
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2008, 09:50 PM
Tags for this Thread
