Results 1 to 11 of 11
Thread: lost 3rd and 4 th gear - error 36-
    VR Executive Series 2
    Sep 2008
    Yarra Valley
    Default lost 3rd and 4 th gear - error 36-
    yesterday my vr series 2 lost 3 and 4 th gear got home checked fluid levels, all ok, ran a code check and it came up with 36 - vaccum leak-, would this error cause the car to go into limp mode? Or is there going to be a bigger underlying problem?
    Thanks for any help
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you've also lost reverse the fault will be a busted sun shell in the auto which is very common. Otherwise I'd reset the ECU by pulling the engine fuse for 10 secs and the drive the car and read the codes again.
    Re the code 36 - can't help you as to whether it will make the car go to LHM ....maybe if it senses no vacuum it figures that you have no power assistance for the brakes and goes to LHM. Hope this is of some help.
    Good Luck.
    Sep 2008
    Yarra Valley
    still got reverse, starting to think the 3rd and 4th clutch has burnt out, any way too check this?
    Vr Executive 3.8
    Dec 2008
    Code 36 won't make your car go in to limp mode, I've had this code since I got the car and the only noticeable ill affect (I think) is a unhappy idle and shit fuel economy. I don't know much about auto's except what I've learnt through mine stuffing up but yeah do what the other fellas said unhook the battery for ten minutes then go for a drive for a few minutes (5-10) and the computer should log new codes that might shed some light.
    Sep 2008
    Yarra Valley
    fixed vacuum problem still havnt got 3rd and 4th reckon the clutch is gone on them gears, so time for a new tranny
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Read the codes again! - with a bit of luck it will come up with 81 or 82 one of which is shift solenoids in the trans - these will cause it to go to LHM ...a lot cheaper than a reco.
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    isnt limp mode when the gearbox just drives in 4th, and doesnt use the 1st, 2nd and 3rd gears....maybe just try and find a cheep second hand one, a mate said he got one from a wreckers for $70
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    In limp home mode the box stays in 3rd...that means it starts and stays in 3rd - drives like its using an elastic band instead of a motor.
    However, you can still manually select the other gears.
    You might be lucky and pickup a cheap secondhand box but you generally get what you pay for and it's a lot of work wasted just changing the boxes over I reckon.
    Vr Executive 3.8
    Dec 2008
    If you treat your gearbox well (IE don't thrash it) and can do the swap yourself I would go for a wreckers gearbox, its luck of the draw but I'd rather fork out $385 for a gearbox with three months warranty before spending 1500-2000 on a reco/new one.
    vsiicalais's Avatar
    vsiicalais is offline Donating Member
    VEII Thunder SV6
    Aug 2007
    Warragul
    Quote Originally Posted by hako View Post
    your right there, my car went into LHM the other week when the alternator packed it in so i had next to no power to keep the car running. I had to drive about 2 km to get home in LHM but even the cyclists on the orad were going faster then me. Glad i didnt have to take off up any hills cause i dont think i could of made it
    How To - Fix Reverse Lights For Free!
    http://forums.justcommodores.com.au/...commodore.html
    vr series 2 v6
    Oct 2009
    nsw
    Default i have a similar problem
    i lost 3rd and 4th, will take off in D but soon as you get to 3rd gear she revs for the skys and goes no where????
    2nd gear everywhere is not good, as she only does 130km in 2nd haha, any ideas?
    these solinoides things, are they in the sump of the gearbox when you drop it out?
    cheers again
  1. error code 18 and no first gear for auto trans
    By -=ApheX=- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-07-2008, 10:53 AM
  2. lost
    By glowworm in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-04-2007, 09:51 PM
  3. Lost Key
    By brownie82 in forum General
    Last Post: 24-10-2006, 10:34 PM
  4. i'm a bit lost!
    By Morganv8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2006, 12:09 AM
  5. vl has lost top gear
    By PCJ in forum General
    Last Post: 15-04-2006, 01:01 PM
Tags for this Thread
