bought a cargo barrier for my VR but having trouble fitting it.where are the top holes to fit the hinges on the body? dont want to rip away the lining and find there is nothing there
There should be some nuts in which to screw in the upper brackets hidden behind the roof lining. They are located somewhere above the rear windows. You will need to partly remove the head lining to find them. When you do just mark where the nuts line up behind the lining and then make a hole for the screws. If I get a chance I will photograph the area for you.
any chance of those pics?
