Hi again,
I need to recondition my ignition barrel. My favourite wrecker guy gave me the inside part in order to change it myself. He said there is a button to click somewhere around the metalic housing, once you turn the key, to release the inside bits.
I have searched everywhere around that zone and could not find that damn button..
Any help is welcome.
Found it. Thanks!
Cant get the barrel to move more than half a mil.. Do I have to pull really hard or did I miss something..
From memory it should come out easy. Often the barrels need replacing because parts break off inside causing problems, maybe a broken part is stopping it from coming out. I'd try a little more force.
MY RIDE
The part that snapped off was the end bit.. the one that goes inside that black plastic swich cylender. So I doubt there would be anything in the way at this stage.. Maybe I should ask a specialist to do it for me.
Well I suppose.. It's the only position where it seems to be in phase with the hole. So not the first click but the second.
MY RIDE
I just did mine, was stuck really good, just pull harder. make sure the button keeps in, and pull more (and yes, key needs to be in ON position)
Current mods/repairs:
Power Windows Installation (70% Complete)
Current Issue(s)
N/A
My Holden doesn't leak, It's just marking it's territory!
So what tool did you use to get a grip on that thing without damaging?
I used the key to pull it a little bit out and then reefed it with my fingers
Current Issue(s)
N/A
