Results 1 to 11 of 11
Thread: vr s2 only clicks instead of turning over. Starter
    Steve Ashton's Avatar
    Steve Ashton is offline Proud Commodore Owner
    vr series2 executive wagon
    Mar 2009
    Brisbane Australia
    Default vr s2 only clicks instead of turning over. Starter
    FIRST POST,, My vr s2 , 6 cyl Has been turning over more slowly & i thought the battery must be on the way out , but after last night it only makes a single click sound unless you try 10 times and hold the key for ten seconds. Changed the battery last night & is still doing the same thing even when hooked up to both batteries. Changed the starter motor in our vn ,once, ( now retired to the front lawn ) it was a heck of a job sqeezing the starter in. Wont be long & this one wont start at all. If anyone can offer some tips on were to start looking for the problem , if the vr 6 has the same starter motor as the vn 6 and maybe an easier way to fit the starter in. That would be great Thanks heaps !
    Mar 2009
    Brisbane Australia
    Or just the first place to start looking after the battery, terminals and the key is fine . Thanks .
    mx kid's Avatar
    mx kid is offline 5th pinned
    VXII CLUBSPORT
    Apr 2009
    Perth, WA
    im assuming its auto?
    definitely sounds like starter motor. the alternator shouldnt be an isuue if you put a brand new battery in it. and if its slowly died then i starter motor sounds like the problem
    it should be the same starter motor... dont think it changed from VN to the VR/VS
    had a look around for a diagram for u but no luck. try searching the forums for a diagram or get ur hands on manual if ya get lost doing it. should be easy just to bolt on exactly the way u took it off tho.
    good luck mate
    vp ssv 5 speed ,vs aclaim
    Jan 2009
    brisbane
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Unless the battery is fully charged and registering at least 12.6 volts I would suspect the battery. However also could be the starter but check the battery first I reckon.
    I've stuck a link to a "how to" on changing the starter motor...might be a few tips. Good Luck
    How to Change a Starter Motor
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Its not the starter motor. Its the solenoid that connects to Starter Motor. Replace that and she will be good as gold. Its the excat same thing as what was happening with my Dads Kia Pregio Van.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You can check if it is the solenoid by turning the headlights on and then try to start the car - is the starter clicks and the headlights go real dim it will be either the starter motor or the battery but if the starter clicks and the headlights do not dim it will be the solenoid as Mumboman suggests.
    VS Wagon
    May 2007
    Kealba
    just check to see if the push on soleniod wire on the starter solenoid is a snug fit.mine was clicking at first start in the morning.I found this push on terminal to be loose.Changed that and now as good as gold.worth a try before you do anything else
    VZ SV6
    Oct 2008
    Newcastle NSW
    Quote Originally Posted by paytons_dady View Post
    check the coil pack dude hapend to mi mates vr today
    A failing ignition component won't stop an engine from cranking.
    I still reckon its a failed battery as hako suggested, considering the starter speed has got slower and slower over the last few starts as you said, which is consistent with a dying battery...
    Mar 2009
    Brisbane Australia
    SORRY LOST MY OTHER REPLY, TIMED OUT .
    Thanks to "all", for your advice ! This time, Mumboman was spot on and it was the wire to the solenoid. The lack of a spring washer and a little to much oil, caused the problem.( I had never had things slowly deteriate like that before, with the problem being a loose connection. Should have been the charge in the battery, but the indicators where working perfectly with the high beam & brake lights on.)
    The problem REALY started when i tried to take the soleniod nut OFF. The thead was KNACKERD and the bolt snapped out of the solenoid. The good news is that ""the solenoid is the only part of the starter motor on the VN that is interchangable with the VR"" (that i could use anyway) . I think the SM changed for the VP. The SM is bigger in the VN , has different posititioning and is held on by three bolts & not two as in the VR.
    All up and running just like a champion !! Thanks again
    Mar 2009
    Brisbane Australia
    QUOTE from hako
    How to Change a Starter Motor[/QUOTE]
    You're a good person hako,,, thanks for the help ! CHEARS
  1. indicator not turning off when turning corner
    By jared_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2009, 11:11 PM
  2. vp turning off
    By clitzyfgi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-10-2008, 04:27 PM
  3. vp turning off
    Last Post: 08-10-2008, 07:04 PM
  4. Revs at 100 clicks
    By Rzeractor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-09-2008, 08:15 PM
  5. amp not turning off
    By Burnout_bro in forum Car Audio
    Last Post: 01-09-2008, 10:05 PM
