+ Reply to Thread
Results 1 to 10 of 10
Thread: trans fluid pushed back out?!?!?!
    GAMBLR's Avatar
    GAMBLR is offline More trouble than u think GAMBLR Berlina
    '04 VZ Calais LS1
    Dec 2006
    Whyalla (yawn), South Australia
    Default trans fluid pushed back out?!?!?!
    Hey there everyone
    I'm in need of some fairly urgent help. For some reason during the past week, the VS has been squirting transmission fluid back up through the spout in the engine bay, pushing the red locking cap and dipstick out of the way in the process. all three times i drove it, car was cold and i wasn't pushing it harder than usual. yet i drove it over 400km on the weekend after the first time it happened, not a problem.
    before anyone tells me that was stupid, i ran the car for a good hour before i travelled and nothing happened, so i assumed it was a once off.
    i have checked the trans cooler breather lines (2) near the radiator, but yet to do anything else. this obviously didn't solve the problem. anyone who might know what the problem is and how to fix please let me know. i believe there is another breather line attached to the actual trans under the car but yet to check that one
    Cheers guys
    CC
    CruznCalais
    [GAMBLR]
    The VZ is here! About time!
    camstatic's Avatar
    camstatic is offline on cruise-control camstatic Berlina
    VP S1 V6 Executive
    May 2006
    Regional SA
    How long since you've serviced it? I've heard a blocked filter can cause that.
    Check out my VP right 'ere!
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker vlv8vic W427 vlv8vic W427 vlv8vic W427
    M5
    Mar 2005
    Australia
    Not a trans person but to check the obvious - could it be massively overfilled?
    GAMBLR's Avatar
    '04 VZ Calais LS1
    Dec 2006
    Quote Originally Posted by camstatic View Post
    have heard that too, getting a new filter at lunch time cos my mate is having a look at it for me. hasn't been done in over 3 years since i bought it, but it has only done 30k km since i got it, so it's probably around due. i was told every 30-40k to get it done
    Quote Originally Posted by vlv8vic View Post
    not as far as i'm aware, i filled it not long ago to where it needed it, and i did it properly, as in add some, run through the gears to flush it through the system and add more if it needed it.
    not as a dig, but how could overfilling it cause it to do this? and it hasn't been topped up for ages, so why has it only started it now? more questions, not enough answers lol
    cheers heaps guys
    CruznCalais
    [GAMBLR]
    hako is offline Donating Member hako Senator hako Senator hako Senator
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It can happen if the transmission oil cooler which is inside the radiator side tank develops a leak - coolant is then forced into the transmission and when the fluid reaches 100 degrees C the coolant boils and forces the dipstick off.
    The other cause is when the breather hose gets blocked - wasps build nests there plus they do get clogged for whatever reason.
    Final reason is when the transmission is pushed or very worn and the oil overheats and boils pushing the dipstick out though generally the breather can handle that.
    Good Luck.
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    Quote Originally Posted by CruznCalais View Post
    cheers heaps guys
    No idea mate, just chucked an idea based on what you originally posted.
    GAMBLR's Avatar
    '04 VZ Calais LS1
    Dec 2006
    Quote Originally Posted by hako View Post
    Good Luck.
    cheers hako. i personally have no idea, im not cluey when it comes to engines and trans, so any help i can get is a bonus. info is really helpful cheers mate
    no worries. again, not having a dig, more like 'would you know why...' kinda thing. cheers anyway
    just went and picked up the trans service kit and a bottle of fluid. take it to my mates after work and pray it works...
    cheers again guys
    CruznCalais
    [GAMBLR]
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As I suggested before, check the breather - it's the black rubber hose in the general whereabouts of the bellhousing...if it can't breath the only escape for the fluid which expands with temperature is up the dipstick. Don't try to clear the breather tube by blowing up the tube as that just blows crap into the trans - remove the hose to clean.
    Another possible is the actual dipstick - if you look at it closely you will see the it has one or two (not sure) "O" rings which are squashed when you flip that toggle lock thing. If the "O" rings go hard with age they will not compress and expand when the dipstick is locked...and if they don't expand they don't seal or grip the filler tube - result id that the dipstick creeps up the tube.
    GAMBLR's Avatar
    '04 VZ Calais LS1
    Dec 2006
    cheers hako. i wasn't too sure about it all, so i had my mate's dad check and service the trans for me. i didn't think it was bad as it was, but it was done thursday night and the trans has never run more smoothly.
    as for the "O" rings, i think mine have both come off, so will have to replace them asap.
    again cheers for the help guys, much appreciated
    CruznCalais
    [GAMBLR]
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    That's great news....nothing like followup. If the "O" rings are missing that will certainly cause the dipstick to ride up the tube.
+ Reply to Thread
  1. Car leaking a lot of trans fluid
    By VS_Wagon_Baby in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2008, 10:39 PM
  2. trans fluid colour.
    By dylanfh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2008, 04:18 PM
  3. Wheel Being Pushed Back.
    By mischa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-05-2008, 10:10 AM
  4. Water in with the trans fluid!
    By JD in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-10-2007, 06:35 PM
  5. Brake Fluid and Auto Trans Fluid.
    By Melchior3 in forum General
    Last Post: 20-02-2006, 11:49 AM
