Results 1 to 12 of 12
Thread: vs radiater leaking coolant from side tank????
    VS ECOTEC
    Sep 2008
    Default vs radiater leaking coolant from side tank????
    Gday everyone
    I have a vs commodore, and i think its leaking coolant from the drivers side but not from hoses.the mechanic said it could be the side tank,If not the core of the radiater 150-500 dollars.....If its not coming from the core,How do you repair the side tank,The wreckers only have series 2 radiaters and mine a series 1...And they said they could order one in for 2 hundred dollars near new.If anyone could give me some pointers,/it would be appreciated..Cheers hk-vs.
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Don't think there is much difference if any between series 1 and series 2 radiators. From my understanding you should be able to do a remove and swap which is very easy. Honestly when a radiator is leaking coolant and a Mechanic says its broken somewhere, i would just replace the whole radiator. Although be careful as some mechanics will say one thing just to get some $$$ out of you.
    VS ECOTEC
    Sep 2008
    Quote Originally Posted by Mumboman View Post
    Thanks for that,Just got a quote to replace side tank...130 dollars.
    VS ECOTEC
    Sep 2008
    Series two are screw in transmission lines,mine clip on.
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Ah ok... see you learn something new everyday. Its a dam they changed those little things otherwise you would be all sweet with a series 1. Wow $130 to have just the side replaced... Try and look around at the wreckers for a Series II radiator. You can normally pick them up for $150.
    VS ECOTEC
    Sep 2008
    I have to take it out and hand it to them,Or if they take it out its 400joke....The mechanic said if its the tank 150,so i have booked it in...Otherwise i have to pay 200 dollars for a near new on. lol
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    VR Acclaim
    Sep 2008
    Kingsley WA
    Two weeks ago the driver's side tank on my VR developed a crack. I picked up a new radiator for $99.95 on ebay plus $34 delivery to WA. It took 7 days to get here from NSW. It is a simple job to install.
    VS ECOTEC
    Sep 2008
    Dam mate... Where abouts are you located?
    Redcliffe Qld....See what happens tuesday mate.
    VS ECOTEC
    Sep 2008
    Quote Originally Posted by 08sky_way View Post
    I could get another for 200 near new and put it in myself,Gee I dont even know if it would be near new since its a wreckers thats would have ordered it in.My mechanic said that if its the side tank he would fix it for 150,If the core in the radiater is all right.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check Ebay - put 'commodore radiator' into the search engine - brand new ones for $99 with 2 year warranty and 2nd hand ones with fan for $20 (buy it now price)
    VS ECOTEC
    Sep 2008
    Thanks everyone,I got this new one of ebay for 99.95 plus 28.35 postage 128.30 all up...Cheers HK-VS
    http://i43.tinypic.com/md05k9.jpg
  1. Coolant leaking from something...
    By LightningVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2008, 12:59 AM
  2. leaking coolant
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2008, 10:11 PM
  3. Coolant leaking from front Left (Drivers side)
    By Hot-Rod in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-03-2008, 11:48 PM
  4. Leaking Coolant
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-05-2006, 08:49 PM
  5. Coolant Leaking Help Vn
    By WeBsTeR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-01-2006, 08:18 PM
