I have a 95 vs wagon and for sometime i have noticed water dripping in from under the trim above the window either side in the luggage area.Upon closer inspection i cannot seem to find anywhere where water is seeping through from the outside,thought it might be running in from the gutter chanels but nothing seems to be obvious.Does anyone else have this problem and if so do they know a solution?
Remove as much trim as you can (inside and out) and check for rust and maybe look for bad seals.
cant say i have the same problem, but i doubt its from the gutters. It wont cost much to go to a local window installer and aske them to reseal the window if you can confirm it is that, which is most likely as there i nowhere else really
