Results 1 to 9 of 9
Thread: Horn issues
    VR Executive S2 Wagon
    Apr 2009
    SA
    Default Horn issues
    Hello All,
    Well got my new VR wagon and the horn does not work all the fuses are good (tested with multi meter) But when you pull the horn bit of the string wheal The ground cable was off and when you put it were it has to go the horn still does not work and my friend told me if you touch the ground cable with the bolt it should make the horn sound but it does not? does that mean i need a new horn bit for my string wheal or could be it something else?
    Thank you.
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    try hotwiring the horn first, straight from the battery and an earth point. see if it works then. If it doesn't you know the horn itself is screwed. If it does work then time to work backwards for a loose wire or bad connection. I doubt you'll have to look far though, it'll either be the horn or the switch.
    By "touch the ground cable to the bolt" i assume you had the car on and were also pressing the horn pad? You gotta actually push the horn for it to work.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Thumbs up copper pin behind the steering wheel
    Some times its the copper pin behind the steering wheel they wear out over time so maybe pull the steering wheel off and look at the pin to see if it is still making contact with the circular plate!!!
    Apr 2009
    SA
    Okay where about is the horn its self located in the VR model. also would putting a push button to the cables where the horn switch is and try that? or do you need a holden or a horn switch?
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    try anything you like mate. a horn probably the most simple circuit on the car. the worst you are going to do it blow the fuse. I assume the horn is somewhere behind the front bar.
    VS l67 statesman
    Dec 2008
    Its whats the rooster said I had this problem before there are also a couple of terminals in the plastic bit that may need to be relocated
    But its easier to just replace the set up with the brass pin
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Default how much
    Quote Originally Posted by vsl67 View Post
    What did you pay for the parts and where from, i need to do the same but just never got around to it?
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Its the plate that connects onto the brass pin is out just afew mm. My dad had the same problem, he just drilled a screw into the plate so it would hold and she is as good as gold now. Can get some pics if you like.
    VS l67 statesman
    Dec 2008
    I got one from the wreckers they are about $10 but the trick is finding thats not stuffed
  1. Horn not there
    By Lipdog81 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-03-2009, 10:15 PM
  2. Horn and Alarm Issues Maybe
    By StatoSteve in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-11-2008, 08:12 AM
  3. Horn??
    By gupatrol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2007, 11:42 PM
  4. Vt Horn
    By daffyy30 in forum Electrical Wiring / Questions
    Last Post: 11-03-2007, 02:32 PM
  5. Replies: 3
    Last Post: 03-02-2007, 09:51 PM
