Results 1 to 8 of 8
Thread: vr overheating
    Rumbl's Avatar
    Rumbl is offline = ShAkE AnD bAkE =
    VR V6 berlina-VS ss
    Jan 2005
    campbelltown nsw
    Default vr overheating
    hey guys i got a vr v6 i have overheating issue's.
    Ive changed the radiator,thermostat,all hoses,coolent,and switches and even bleed the system and when i drive the temp goe's up to full in the red then after about 1min the temp goe's back down to half way it doe's this about 2 times a day.
    What would this problem be water pump perhap's or just need to be bleed again?
    VR Commodore
    Jun 2005
    could be water pump... check the pump or need to be replace... once if u replace the water pump .. will need to bleed the system again with fresh coolant.. hope will help u?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    From your description it sounds to me more likely your temp gauge is mis-reading. It shouldn't be the waterpump as it wouldn't apparently cool down again plus it is very rare for waterpumps to stop pumping (impeller needs to be completely corroded).
    Next time it goes to red, pop the bonnet and feel the top radiator hose and the radiator side tanks - unless they are very hot and you get a hot engine smell it will not bet overheating. Then make sure the connector that goes to the temp sensor is on properly and not damaged.
    Maybe also bleed the system and make sure the heater is on when you bleed.
    Good Luck
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Quote Originally Posted by hako View Post
    Good Luck
    What this guy said. Seriously.
    I don't see it being anything other than a faulty gauge. Buy a calibrated temp gauge and install it if you really wanna be 100% sure.
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Make sure you also check your Temp Sender. As it maybe sensoring it correctly but may not be sending the correct information to the Cooling System Gauge on your cluster.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    For less than $50 you can buy an infared thermometer that reads dead accurate in a split second and doesn't have to touch the measured surface - I've seen them at tricky dickies for about $29 and they are mighty handy for all sorts of things. I use mine for measuring the temperature of my beer.
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Check the connector on the temp sender...(not too sure where abouts on the V8's.)
    If that seems ok revise your bleed technique.
    LOL at Hako too.
    00 SS M6/79 chev Monza
    Mar 2005
    new t stats have been known to fail many many times
    personally as my own safety i always drill 2X3 mm holes in them to provide at least some water flow if it fails
LinkBacks (?)
  1. Amp Overheating
    By acarmody in forum Car Audio
    Last Post: 25-03-2009, 10:15 AM
  2. vn still overheating
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-12-2008, 02:58 PM
  3. V S overheating
    By Johnno.o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2007, 01:27 PM
  4. Overheating!
    By nicko451 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-10-2007, 12:13 AM
  5. Help, overheating
    By discostuee in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2007, 12:35 PM
