Results 1 to 5 of 5
Thread: Quick inlet manifold removal question
    VR Executive S 3.8
    Oct 2007
    Default Quick inlet manifold removal question
    Have a V6 VR which I'm pulling the inlet manifold off. Now do I need to remove the fuel injectors from the manifold before I can remove it or can I just leave them all on there (along with the fuel rail) and pull them off with the inlet manifold? I just figure it'll be simpler and then won't have to bother replacing the injector O-rings.
    vq rat's Avatar
    vq rat is offline vq rat
    vn bt1 burnout weapon
    Mar 2006
    hamilton vic
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Yep just leave the injectors and fuel rail there buddy. It will all just come out as 1. Make sure you depressurize the fuel lines before disconnecting them as this can cause damage to the return fuel line if you don't.
    Mumbo Man
    VR Executive S 3.8
    Oct 2007
    Nah no doing. The inlet manifold bolts were just to difficult to access with the fuel rail in the way. The O-rings on the injectors look ok; I imagine it'll be ok to use them again (cars on LPG anyway)?
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    Better off getting new O rings mate, or at least keep them moist in something, I didn't replace them once, thinking it'd be allright, ended up having a world of issues with a vacume leak.
  1. Inlet manifold... DOH!
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2011, 04:46 AM
  2. l67 inlet manifold
    By Adrian in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2008, 12:46 PM
  3. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
  4. wtb: inlet manifold for vh
    By white vn ss in forum Swap / Wanted to Buy / Trade
    Last Post: 12-03-2006, 12:47 PM
  5. inlet manifold
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-08-2005, 04:19 PM
