Results 1 to 5 of 5
Thread: Alternator noise
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Default Alternator noise
    My alternator is making a grinding/whirring noise, could it be a bearing? If so how do i replace it?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    That will be the front bearing - it is replaceable for under $10 but you need to remove the rotor and front pulley to fit it. Take your time and it can be done.
    Good Luck.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by maldotcom2 View Post
    It probably is a bearing. You will need to pull the alternator apart to replace the bearing(s). A very simple job really. You will probably need a puller to get the bearings of the shaft.
    MY RIDE
    Dec 2008
    Just took the belt off and spun all the pulleys, it's the tensioner pulley! Is there a bearing in that or do i need a new assembly?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You can replace the pulley for around $30 from Supercheap, Repco, Bursons etc. The bolt that holds it on is left hand thread (turn it clockwise to undo it.)
    MY RIDE
  1. Alternator not charging, no alternator light
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 05:55 PM
  2. ch ch ch ch noise on start up - alternator?
    By timmy_tam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-12-2006, 06:39 AM
  3. alternator high pitch noise
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2006, 05:23 PM
  4. Idler Pulley noisy?? & Brushing noise from alternator
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2006, 08:15 PM
  5. Alternator noise ?
    By VSAccCom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-10-2005, 03:24 PM
