Results 1 to 11 of 11
Thread: i need help my rear of my car shudders at about 80kph when i hit the gas
    94 VR CALAIS V8
    Jan 2009
    Cool i need help my rear of my car shudders at about 80kph when i hit the gas
    hey there i have a vr calias 94 v8
    and from time to time when i am driving at about 80kph i get a suddering when i hit the gas i really need help to fix this problem, please let know of your suggestions
    Vr V6 mazda 808, VN S1, VH SLE
    Oct 2007
    Hobart
    hey bud, it could be something simple like your universals in your tailshaft.. check them and make sure there is no movement there!! could be your problem!! hope that helped..
    happened to me once in a hilux..
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Unfortunately it sounds like your TCC (torque converter clutch) is starting to play up. The TCC usually locks the torque converter solid at speeds above 80kph and if it's starting to fail it will shudder/vibrate etc. I'd treat the car gently till you can get it looked at by an auto trans man. Also check the transmission oil level. Hope I'm wrong.
    94 VR CALAIS V8
    Jan 2009
    Quote Originally Posted by hako View Post
    i dont think its my TCC because i just had my tranny fully seviced and a stage 2 shift kit put in it.... but i will talk to my tranny bloke and see what he says
    thanks bro
    94 VR CALAIS V8
    Jan 2009
    Quote Originally Posted by munchmunchrotors4lunch View Post
    thanks bro i will have a look
    cheers
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    I had a similar issue when I converted from auto to manual transmission. It turned out that the phasing of the tailshaft was wrong. The tailshaft was overhauled during the trans conversion but was not installed properly.
    muttley383
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    I've noticed the same thing. In low 4th if i press the accelerator lightly or just cruising it vibrates and makes crap all power. If i stamp it or manually drop it back to 3rd there's no problem.
    VP Executive R-spec
    Jan 2005
    For the 50 bucks they cost all you guys should first and for most put a new gearbox mount in. They don't take long to fail on a 5 litre and the part has been superceded with a better one as the originals were no good. That will fix most few of you up then the rest can get on with finding another problem. If you have a driveline vibration chances are it's comming from the driveline and the mount holds it all straight, suspect number one if everything else seems tight and good
    94 VR CALAIS V8
    Jan 2009
    Quote Originally Posted by greenfoam View Post
    hey bro i already put new gearbox mounts in it about 2 weeks ago when i had a stage 2 shift kit put in, so maybe they did not put my tailshaft in properly i will ring the tranny and diff bloke on tuesday and give him a serve.....
    cheers
    94 VR CALAIS V8
    Jan 2009
    Quote Originally Posted by NVME-69 View Post
    cheers
    from what it looks bro the tailshaft looks tight....
    94 VR CALAIS V8
    Jan 2009
    Quote Originally Posted by muttley383 View Post
    yer thats what i think it might be too i will talk to the tranny and diff bloke on tuesday
    cheers bro
  1. VT shudders under brakes
    By Easy Rollins in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-11-2008, 05:06 PM
  2. car shudders while driving and taking off
    By VT1988 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-05-2008, 07:16 PM
  3. Stupid Violent Shudders
    By fentos in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-10-2006, 12:01 PM
  4. VT Brake Shudders
    By Secki in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2005, 03:06 AM
  5. Got the shudders
    By ralph in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2004, 09:31 PM
Tags for this Thread
