Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: VR Climate Control, feet only??
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    Default VR Climate Control, feet only??
    Hi Guys,
    Ive had an issue for awhile where my climate control now only cools your feet?
    A VERY small amount of air comes out of the correct ducts, but most of it hits your feet, no matter which mode its on.
    Swapped over the solenoid box thinking that was it, but no, exact same issue.
    Anyone got any light to shed on this?
    The hoses still seem intact, & with the centre console out, I can see that its blowing from the ducts below those that route to the rear thru the centre console.
    Please help?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    are all the vac hoses connected to the valves?
    Can you move the side valve (drivers side up under the dash) by hand - ie open and clise the vents.
    Also I have printouts at home of all the VQ climate setup from the big book. I can bring them into work if that will help you.
    and 3 Dangerous non ABS VN's
    vr berlina
    Oct 2007
    Sunny Coast
    Mate I have the exact same drama. and was just going to start a thread on this. Hope that there is some that can help us
    All GO
    NORTI's Avatar
    May 2004
    Quote Originally Posted by 88GreenVN View Post
    do you mean at the solenoid end? the little rubber vaccum manifold??
    Looks like all the hoses from the dash are into the back of the manifold, & then I made sure all the white plugs were snug into the manifold.
    Im going to go look for this side valve now!
    BBS!
    88GreenVN's Avatar
    Jun 2006
    The vacuum opens the valves to let the small gates open and close - directing air flow. Can you move them by hand - ie not jammed up some how.
    88GreenVN's Avatar
    Jun 2006
    Here is a photo of the things you need to make move
    Attached Thumbnails Attached Thumbnails VR Climate Control, feet only??-heater-box.jpg
    NORTI's Avatar
    May 2004
    88GreenVN's Avatar
    Jun 2006
    You will have 4 of them.
    NORTI's Avatar
    May 2004
    88GreenVN's Avatar
    Jun 2006
    OK the vac lines go to something..... what ever they plug into will drive the vents inside the heater box.
    NORTI's Avatar
    May 2004
    well I know where the red one goes, & where the beige one goes, Il lhave to get the torch uder there again & trace the rest
    88GreenVN's Avatar
    Jun 2006
    If you unplug red one do you hear the air suck in?
    NORTI's Avatar
    May 2004
    cant reach it. it that part only on climate models? or on aircon models too?
    88GreenVN's Avatar
    Jun 2006
    All heater boxes have the small round vac units on the heater box - just the CC units are controled electronicly and have the vac pack under the heater box. The standard system had the vac lines hooked up to the twist control knob.
  15. #15
    NORTI's Avatar
    May 2004
    cool, so I can go raid one off anything.
    Im not looking forward to the fact that it appears I may have remove the whole crash pad to get at this piece of crap.
  16. #16
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by NORTI View Post
    No - should only need to remove the front panel (radio bit) to get to them. Also the black plastic bit under the glove box.
  17. #17
    NORTI's Avatar
    May 2004
    Already have taken off all the radio surrounds etc,
    its way way underneath, Im going to have to take out all of the aircon ducts to see if that gives me more room
  18. #18
    88GreenVN's Avatar
    Jun 2006
    yes that will help
  19. #19
    VSII Berlina
    Apr 2007
    rural SA
    after reading this thread last weekend i went and ordered the solenoid block and fitted it in this morning. absloute friggin pain in the arse spot to get at but after about 2hrs stuffing around, took it for a drive and FINALLY the climate control works perfectly! haha woot
  20. #20
    NORTI's Avatar
    May 2004
    lol I think that might be a different thread.....
    Im glad yours worked out okay, wish mine was fixed by that
  21. #21
    VSII Berlina
    Apr 2007
    rural SA
    lol oh yeah, seeing as you only started this thread today... one im thinking had the part number for it posted
    yeah really happy that it did fix it, and that i hadn't wasted 90 bucks on something that wasn't broke
  22. #22
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Check the T piece going onto the manifold again and make sure the one way valve is facing the right way and works. Should be only able to blow through it one way.
  23. #23
    NORTI's Avatar
    May 2004
    thx wavez, Ive narrowed it down to a vaccum issue somewhere involving the black hose....
    Ill check the T-piece again...
  24. #24
    88GreenVN's Avatar
    Jun 2006
    Check the line into the vac ball under the front left gaurd too.
  25. #25
    NORTI's Avatar
    May 2004
    Okay, so here is the saga....
    after 3 solenoid boxes (yes 3, I went & got ANOTHER one), 2 climate control dash units, 2 spare vaccum diaphrams, & a very handy piece of hose.....
    its fixed!!!
    So, we narrowed it down that the dash thingo, is fine.
    The solenoid box is working correctly, & using the hose we cycled thru & sucked/blew thru all the valves to check. - Allgood.
    So then maybe not getting vaccum in? Checked recently replaced vaccum ball connections, allgood.
    CHecked T-Piece has 3 hoses... whoa, one not connected, ah-ha you say? Noooooo, connected said hose, still an issue
    Recheck all actuators with the hose.... all of them work....
    Back to engine bay, use hose to check vaccum going thru firewall, allgood.
    Still why not working?? hmmm, follow all vaccum lines around engine bay, remove engine covers, crawl over manifold....
    then sit & think.... did aircon play up before or after new spark leads??? After!!
    By feel, find that there is a small nipple for one of the hoses on the t-piece to attach too, guess what? when doing the lead change, have knocked little itty bitty hose off....
    for refrence, this hose is located to the right of the dizzy, underneath a larger hose that runs under the dizzy, cant see it, definetly cant take a photo lol
    so great drama is finally over, & much dust entered my car after 6mths of no face vents working lols....
    (as a side note, I realise that I totally bluffed my way thru regency about the demister.... ha!)
  1. Climate Control/Standard Heater A/C Control
    By swift85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-03-2009, 07:44 PM
  2. Climate control
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2008, 06:51 PM
  3. VS Climate control
    By <RaBBiT> in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2008, 11:29 PM
  4. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  5. Climate control?
    By cladiges in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2006, 06:21 PM
