My ute has lost low speed interior fan 1 and 2 , 3 and 4 still blow air , a/c on or off its the same.. no air circulating on fan speed 1 or 2 , but blows air fine on 3 and 4. I have checked fuses and relays under the bonnet ( there is none for it under dash - mine is a series 2 VS ) they were all ok ,Have fitted an new fan speed switch , even swapped the relay for the horn relay next to it ( which i know works ) , but still have no low speed fan. Any ideas?
Its not what you know or who you know , its how well you can fake it
Fan resistor is busted - top of the heater box under the wiper cowling. Very common issue and there is a how to fix thread some place on here
and 3 Dangerous non ABS VN's
cheers.. i'll pop the bonnet now and go hunting
You need to remove the wiper arms and the plastic cowl sheild. There is a small cover to remove to gain access to the resistor pack.
Just get a new 1 from holdens. I replaced mine about 18 months ago, it cost about $40.
Be carefull removing the plastic cowl sheild clips. I have heard of some people ending up cracking their windscreen![]()
are the 2 the same? as in if i get one from the wreckers , will the 3-4 fit in or are they specific as to what they are supposed to run?
Here is the link on your exact problem and how to fix it:
Replacing the Fan Speed Resistor
cheers hako.. have just finished reading it.. will be off to the wreckers tomorrow for a replacement and a spare
The new 1 from holden is different. It doesn't have the wire coils that seem to burn out. It looks like the resistors are now sandwiched between 2 heatsinks.
the newer resistors still fit and work though i have the new type in my vr and it works fine
Well finally made it to the wreckers and pulled 2 out ( most were already taken ) as i want a spare.. cost me nothing ( cept the $2 entry fee ) , installed it , and hey presto , fan works on low speeds now.. thanx all for helping solve the problem.. now tomorrow i can gas my A/C and throw some tyres on the front!.
p.s i do AC for a job , topping up ac is childs play![]()
