Results 1 to 4 of 4
Thread: Radiator connections on vs series 2
    VS Commodore Series 2
    Apr 2009
    Default Radiator connections on vs series 2
    Hey,just wondering i am in the middle of replacing my radiator in a vs series 2 and i got another one from the wreckers but it looks as though they gave me a series 1 with the clip on transmission hoses.Is it possible to replace the screw on fittings from my old radiator onto the series 1 because i have tried to unscrew them but looks like there attached inside the actual tank or can you get attachments adapters from repco etc.thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    They don't screw off unfortunately....and connectors to adapt it will cost quite a few dollars if you can locate them. You may well be able to bodgy up something but there is always the chance of the hose slipping off and then you have no transmission. I'd take it back and get the series 2 radiator...it will save a lot of hassles.
    Good Luck.
    Apr 2009
    Yeah,ive came to that conclusion too.I will just take it back and get a series 2 one.Very stupid of me not to realise when i got it.Even more stupid of me not to realise it before I took the old one out.But at least I will be good at taking out and puting a vs radiator back in when Im done (ha ha)thanks
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    it must only be aftermarket ones that unscrew then? I have a SSS radiator, it came with both fittings and they simply screw on, pitty about the stuff around mate, good luck with it.
  1. flush radiator VT Series ll 1999
    By badgez in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-05-2010, 08:07 PM
  2. VT V6 putting a series 2 radiator in a series 1? yes/no?
    By jonnydico in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2009, 07:03 PM
  3. WTB: VT Calais II Series 2 Radiator Grilles
    By VT97CALAIS in forum Swap / Wanted to Buy / Trade
    Last Post: 10-07-2008, 09:49 AM
  4. VN series 1 earthing + radiator fan problems
    By Waz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2005, 10:33 PM
  5. VS series II radiator....screw or clamp?
    By Clacker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-06-2005, 12:18 PM
