Results 1 to 4 of 4
Thread: VR speedo problem
    VR Acclaim 94 S2
    Mar 2009
    Exclamation VR speedo problem
    I have just replaced the cog to fix my odometer but now my speedo isn't working properly, it gets stuck when your speeding up or slowing down and then it will jump to the right speed and it's real confusing cause it takes ages to go to the right speed so I don't know how fast I'm going, I have pulled the cluster out again and the needle was on properly but I took it off and put it on again anyway and when you move the needle it moves freely, Does anybody know whats going on??
    VZ SS-Z
    May 2006
    I'd be interested to find a fix for this too - my 95 VR Acclaim is doing the exact same thing. I was going to take it to an auto electrician to have the problem rectified, but if you find something in the mean time let me know.
    Gus The Snail's Avatar
    Gus The Snail is offline Born to be dizlegzic
    VS ute S2 1996
    Aug 2007
    ipswich - on the right side of the tracks
    how much did you pay for your cog?
    Its not what you know or who you know , its how well you can fake it
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    pull the cluster out,
    Check the plugs in the back of the Dash are all seated correctly, sometimes during remove and refit they can get loose.
    also on the back of the cluster will be information for the pinouts, trace the speedometer pin to the speedo, it should end at one of those brass nuts, if there are no breaks in the circuit on any of the speed's wiring, undo the nuts for the speedo, give the nuts, the washer and the circuit surface a quick clean and refit everything.
    Hope that helps.
  1. rev and speedo problem
    By clazy69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2009, 02:31 PM
  2. speedo problem
    By vkhawkey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-10-2007, 10:59 AM
  3. HELP! speedo problem
    By *VK*chick in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-08-2006, 08:52 PM
  4. Speedo Problem VP
    By holden#1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-09-2005, 07:51 PM
  5. speedo problem
    By Matagi in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-07-2005, 01:57 PM
