Results 1 to 3 of 3
Thread: VS BCM into VR??
    94 VR Statesman
    Aug 2006
    Default VS BCM into VR??
    basically i wanna put a VS high bcm into a VR tried it once but when i turned the key the engine turned over but wouldnt start do i need a vs ecu aswell any dramas i might run into??? if it makes any difference its a 5.0ltr and both bcms are from a 5.0ltr
    94 VR Statesman
    Aug 2006
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Yep they arent compatable, serial link between bcm and ecu uses a different type of communication it needs to get engine to start so one wont work with another model...so you will have to get a vs ecu to work with a vs bcm.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
