Results 1 to 2 of 2
Thread: intake maifold gasket
    93 VR Executive Wagon
    Mar 2009
    Melbourne, Bentleigh East
    Default intake maifold gasket
    i had changed the coolant in the radiator and flushed it out and when i put the new stuff in it leaked a bit from the maifold area. was going to change the gasket so bought the repair book, but after a few days the leak had stopped?? whats going on there. coolant level is fine and not overheating. reservoir tank is full enough too. could the new coolant have just moved some sludge away from the gasket or am i missing something. oh its not leaking water into the oil as well.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Maybe some coolant got spillled and pooled on the manifold some where and was noticed a few days later (I have a vivid imagination)...I'd keep a very close eye on the coolant level and if it doesn't start losing coolant over a month I'd say it was OK.....why this is so doesn't matter - Chinese saying : "Commodore man who look for trouble sure to find"
    But seriously, if the past history of the car indicates that proper coolant was always used - not tap water - then the cooling system will be OK.
  1. normal air intake vs pod filter vs cold air intake: fuel economy
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2011, 09:38 PM
  2. gasket tip
    By vnwagon91 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2010, 09:37 PM
  3. vr v6 gasket
    By myvrcomo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2009, 12:51 PM
  4. 1999 VT intake manifold gasket - I'm lost!
    By javt99 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-06-2008, 10:22 PM
  5. VRS Gasket Set?
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-04-2006, 08:02 PM
