Results 1 to 2 of 2
Thread: code 63
    pando666 is offline milk comes in 2 litres
    vs exec
    Jul 2008
    sydney
    Default code 63
    Ok, I was just coming down the newcastle freeway at 115kph on cruise, light came on(code 63 LH O2 sensor no signal) I switched off cruise, slowly rolled to 100kph light went out then back on cruise, light came on etc, etc, etc.
    While car was at a fixed throttle position light came on when I was rollin down hills, etc light went off, this happened all the way home. Please can someone tell me WTF is goin on.This only started to happen after drivin 300 k's or so it didn't happen on the way up the coast, but it did happen about 4 weeks ago on same trip.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    My first response would be to check connections to the O2 sensor, then I'd run a can of injector cleaner thru the system although if the ECU detects "no signal" from the sensor you'd imagine it's an electrical problem.
  1. code 66 on VR
    By mish22 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2010, 07:05 PM
  2. Code 72 - Vehicle Speed Sensor (VSS) and Code 73 - Pressure Control Solenoid Current
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2009, 04:39 PM
  3. help code 76!!!
    By danny1987 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2006, 05:33 PM
  4. Code 24
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2006, 04:10 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
