I have noticed this for awhile.Dont seem to be using any water or oil.Motor seems to be running fine,although heater seems to take awhile to heat up.Any clues?
Sounds/reads like a gasket!
If the previous owner followed the proper guidelines on coolant he would have added a number of "tablets" - supplied only by Holden with his last coolant change. These "tablets" are supposed to lubricate the water pump among other things and will leave a brown oily deposit on the radiator cap. Also a lot of mechanics will use grease or oil as a gasket/sealant when assembling engine components - this then finds it's way into the cooling system and as oil is lighter than water it floats to the highest point - the radiator cap.
Good Luck.
Not a shitload ,just enough to cause concern.Been like it for about 12 months.
I wouldn't worry too much - like I said before it's normal if the car has been serviced according to the factory guidelines. The heater on Commodores is fairly slow to warm as the heads are cast iron - takes at least 2km to start giving heat...you could change your thermostat which may be jammed open - also check the heater tap....make sure it fully opens when you turn the dial to hot.
so long as it hasn't changed the color of your oil to a milky brown :P
Yeah, check your oil next change... if its really bad (milky) its gonna be either your intake manifold gasket or your heads.... id go IM first as they tend to go more often than the heads do... either way it has to come off should something be wrong!
aZk.
Just changed the oil,nothing seemed to be suspicious.Do you know the correct capacity?
4.3 litres with a filter change or 4.0 litres without.
is the 4.3 for an ecotec ey coz my dipstick is ***ed out so i just been putting 4.5 in but if ur sure its 4.3 than i shall only use 4.3 next time
My ecotec takes the whole 5L to read full on the dipstick...![]()
Haha, that emoticon obviously wasn't worried-looking enough. My point is i have no idea why i can pour around 5L in (definitely more than 4.3L, anyway).
it all depends on how much oil u get out 2 how much goes in.most v6 motors are about 4.5l
Mine takes 5.4 Litres, it's a vy ecotec, even the book states so. Surely the vs ecotecs and the vy ecotecs didn't change their sump capacity by 1.1 litre?
As others have said it sounds like oil, but with 12 months of hassle free driving i wouldnt be worried about it, if your that worried about it speak to your mechanic about a leak down test
