i want to put a vt motor in a vr any info as to if it will go staight in or what needs to be done to get it in
i think the K frames are the same. u will need the engine, box, all the bolt on accessories, tailshaft and all the wiring looms. pretty sure u need to change the fuel pump too.
u also might have to use a VS engine loom on it and then get it wired up to the body loom.
should just chuck a 5L in it. prob work out cheaper. goes straight in and plugs straight up.
