Results 1 to 9 of 9
Thread: booster problem...
    VR Commodore
    Jun 2005
    Default booster problem...
    i have a small problem with booster .. due the upgrade vt brake.
    my car is vr commodore and the vt master cant fit on vr booster
    so i need grab a vs booster to fit in also i have ABS on it... will be work well ??
    thanks
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    I have just completed the VT master and Booster upgrade.
    You are better off getting the VT booster as it is steel, the VS unit is plastic.
    You also have to modify the booster mountng, I purchased a modified new booster from Race Brakes Sydney.
    muttley383
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Get one from me for a lot less...modified to fit your car.....secondhand but I havent had a dud one yet.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    +1 for markovr's VT booster and bracket setup for the VR. Works great.
    Reaper
    Magifil's Avatar
    Magifil is offline Donating Member
    VS Executive
    Jul 2008
    Sunbury Vic
    How much do you charge for them please Markovr?
    Going to a Church is not what makes you a Christian, any more than going to a Garage will make you a Mechanic!
    VX SS M6
    Jun 2005
    Nov 2003
    northside brisbane
    130 + whatever it costs to get it to you usually 15 to 20 ..........with resevoir so the top is level (so it looks factory)on vt/x/y master use au falcon resevoir ...bolts straight up to commodore master or use vs resevoir but you will have to drill and tap new mounting hole in master also maybe upgrade your front strut to master bracket to minimise flex. vt resevoir http://forums.justcommodores.com.au/...-vt-master.jpg and vs/au one fitted http://forums.justcommodores.com.au/...ooster-001.jpg and vs resevoir fitted to a vt upgrade on a sons vh commodore http://forums.justcommodores.com.au/...vh-booster.jpg the vh has only vp finned calipers and a disc rear but with qfm pads the car has very good brakes and a hard short pedal....it was far more economical to upgrade to the vt setup than replace the stuffed 1 inch master with the same new part although the hose adapters are a bit steep.
    Magifil's Avatar
    VS Executive
    Jul 2008
    Sunbury Vic
    Thanks for the quick response I will order one from you next week.
    VR Commodore
    Jun 2005
    hey, i got the vs booster to fit vt master .. still working well as it will stop the brake quickly .. if the vs booster (plastic) snap or f*^k up, will get vt booster, as im happy with my work with upgrade the brakes .. thanks for all of ur help! cheers ..
  1. Vt booster m/c in Vr V8 with ABS
    By VrWagz1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-05-2011, 09:50 PM
  2. brake booster?
    By adam_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2008, 10:51 AM
  3. VX brake booster fit on a VS
    By customcaraudio in forum General
    Last Post: 08-12-2006, 07:08 PM
  4. VN Brake Booster
    By sharpeidog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2005, 11:00 PM
  5. vt booster
    By markovr in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-12-2004, 08:55 AM
