Results 1 to 3 of 3
Thread: Broken Stock Tacho
    96 VS Executive S II
    Feb 2006
    Perth,WA
    Default Broken Stock Tacho
    Hi guys, My tacho has been broken for a while, it used to flicker all over the place - now its just dead, is there anything i can do to fix it? without having to have it looked at? i have checked fuses under the steering wheel and they are ok, and yes i did search, i see that this is a common problem but no answers, any advice would be helpful.
    <insert something funny here>
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Have the same prob with my speedo and got told it was a broken wire on the back of the cluster!
    Might be the same sort of prob for you-
    How to fix speedo VS Commodore
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Pull the cluster out and see what you can see i spose as its not a big job. They also pull apart really easy. 5 screws and 3 little brass nuts and you can have the whole cluster apart and the tacho on the bench. If you suspect the tacho itself, check it for dry solder joints ect.... the usual. Then get another for bugger all off ebay and try swapping the tacho out of it into yours.
    Reaper
  1. stock tacho
    By Phat VN in forum Electrical Wiring / Questions
    Last Post: 20-02-2009, 04:45 PM
  2. Stock Tacho Help!
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2007, 10:30 PM
  3. how come stock 1.8 auto lancer beat stock vl
    By crazy for vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-07-2005, 08:47 AM
  4. VK Calais stock auto to stock 6 cylinder manual.
    By TheKnightTemplar in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-07-2005, 08:01 PM
  5. Stock Tacho Not Working
    By CRAZY-3.8L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2005, 04:30 PM
