Results 1 to 14 of 14
Thread: water on top of engine
    VR Acclaim S2
    Apr 2009
    Default water on top of engine
    I have a VR Acclaim series 2 - I have water pooling in one of the gaps on top of the engine. It's coming from one of the bolts on the driver side. I can see the water seeping out after I drive it. I am new to this, can anyone tell if this is a common problem? What are those bolt for, can I tighten them myself, there are 3 on either side. Any help will be appreciated.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Would it be possible for you to post up at picture at all? From the sounds of it you have a leaking manifold (valley) gasket and this will need to be replaced. This is the gasket that forms a seal between your inlet manifold and your cylinder heads and stops engine coolant mixing with your inlet charge. It is not an uncommon problem at all and is a simple remove and replace procedure to fix.
    VR Acclaim S2
    Apr 2009
    Default picture
    here's a better picture, it doesn't show the bolts but if you've seen a VR engine you'll know what I'm talking about. where the 3 arrows are there are 3 bolts. The one on the driver side closest to the front is leaking water.
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    VR Acclaim S2
    Apr 2009
    Default hey
    I don't know anything about engines. I haven't tried tightening it. Is there anything I can f^#k up by tightening the bolt?
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    not realy just dont try to tighten it too much as it may snap
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VR Acclaim S2
    Apr 2009
    I'll try tightening tonight and see how it goes. Is there a name for that bolt?
    93 VR Executive Wagon
    Mar 2009
    Melbourne, Bentleigh East
    i tightened my bolts a bit and it worked fine. it only leaked cos i flushed the system and it mustve moved a bit of crap from the gasket which mightve been sealing a small crack on the gasket. yeh just dont overtighten them and itll be fine. should be a 3/4 inch spanner or socket to tighten them
    VR Executive S 3.8
    Oct 2007
    There a 3/4 inch bolt. The torque spec for them is 20-25Nm which is quite low. I wouldn't just go and tighten them to much as you may damage the threading.
    Leaking from there indicates your inlet-manifold gasket will need replaceing (or you could try putting some radiator stop leak into your radiator, for a temporary fix). Which is a fairly large job to do. You should be keeping an eye on your coolant levels now aswell.
    Aug 2008
    NSW South Coast
    Retightening the bolts to the specified torque spec may stop the leak, but do be aware that it is likely to only be a temporary fix, and will soon leak again. IMO you would be best off replacing the gaskets. Do you have a workshop manual for a vr and a basic toolkit? With a little bit of mechanical knowledge you shouldn't find it too hard to replace yourself.
    VR Acclaim S2
    Apr 2009
    Should I replace both inlet-maniflod gaskets? Is there much risk involved with a home job?
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by marcoVR View Post
    Seeing though you said you have no experience with engines I think it might be a bit hard for your first attempt. I'm all for people doing their own repairs but I would start with something more simple and and work my way up. If you feel you could do it, then by all means give it a go but it could end up costing you more in the long run.
    MY RIDE
    Aug 2008
    NSW South Coast
    Yes, always replace both gaskets. You will most likely have to buy a top end gasket kit anyway and it will have both of them in it. Maybe if you're not too confident to do it yourself do you have a family member or neighbour etc that is good on the tools?
    VR Executive S 3.8
    Oct 2007
    I did it myself for the first time over the long week end. It took me a couple of days to complete. It's not really that tricky, but a big job being easy to forget were things go. If you haven't done much on your car before, I would be rather cautious about going ahead.
  1. Water Pump efficency and engine performance
    By vol800 in forum General
    Last Post: 09-04-2009, 06:42 PM
  2. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  3. water in engine
    By darin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2008, 09:00 PM
  4. Water ****ing out of engine
    By pranksta in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2008, 01:03 AM
  5. water pump behind engine bloack
    By 3800_man in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-07-2006, 04:22 PM
