hey i have just bought a l67 statesman
the temp gauge usually sits on the 1/3 mark but today i was in the maccas drivethrough and was sittin on about half way just idilin waitin in line
is this normal
yeah it is cause sitting still there is no air passing through the radiator to cool engine down. Did the thermo fans kick in?
yea thermo fans and everything kicked in just noticed it and got a bit scared lol
try replacing your thermostat not to expensive and might fix your problem about $20 from supercheap
Big job replacing your thermostat on supercharged motors-
www.l67torque.com • Login
My S/C Stato sits on 1/4 and will get up to 1/2 in heavy traffic or hot days before the thermo's kick in but never goes over half!
Your safe![]()
the VS gauges are very active in comparison to other models. have a look at the fuel gauge next time you put your foot downquite amusing
as stated above, provided bthe car doesn't go over halfway when idling for a short period, it should be ok. maccas is murder on minemine will creep up even higher than half, still haven't diagnosed the problem...
urs sounds all good tho mate
CruznCalais
[GAMBLR]
The VZ is here! About time!
