Results 1 to 10 of 10
Thread: throttle body problem?
    vr berlina II
    Apr 2009
    Default throttle body problem?
    hey guys.
    ok this is what happened. i took off my throttle body to clean it out and as i thought it was packed with black cr*p. anyway ive put it all back together and now the engine light has come on, and after driving it for a km or so the revs are going all over the place. when i get to about 40km and the gear changes i lose all power and the revs climb roughly up to 3000 without any drive being permited. also if i keep my foot on the exalerater lightly at about 40km the revs go up and down rather than constantly up. it was working perfectly before i took the throttle body off so im guesn it is sumthing to do with it maybe the sensors connected to it? :S please help
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    Did you plug all the sensors back in? You didnt damage any by any chance?
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Go back all over it and make sure all sensors are plugged in correctly in the correct place. Also make sure you have reconnected the vacuum hoses.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    hopefully you didnt let throttlebody cleaner go into the TPS sensor that kills them fast as if by any chance it has dribbled in there you may need a new one check the codes with a paper clip and see what code you get
    vr berlina II
    Apr 2009
    actually i might have? i just checked and code 22 came up, throttle postition sensor low voltage?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    will be full of horrible black crud and carby cleaner most likely stuffed now if its all plugged in properly that is
    vr berlina II
    Apr 2009
    ye thats what i thought it was so i took it apart and double checked i plugged it in again making sure it was in properly. but ye didnt fix it n now that code 22 has come up im guesn the sensor is screwed
    в∞ѕтεכ √&
    Jul 2008
    NZ
    reset the ecu buy pulling the engine fuse and efi fuse in the engine bay or pulling the negative off the battery and see if the code goes away if not get another TPS
    vr berlina II
    Apr 2009
    just have still there. guna replace it n see how it goes from there cheers mate
    в∞ѕтεכ √&
    Jul 2008
    NZ
    how did you go new TPS fix it all up.
  1. Throttle body
    By 7shane0 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2009, 02:33 PM
  2. VL THROTTLE BODY help
    By VL_kid88 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-05-2006, 07:30 PM
  3. Throttle Body
    By StatOmaN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2006, 10:00 PM
  4. throttle body
    By pizzo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2005, 03:20 PM
  5. Oil in throttle body
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2005, 08:31 PM
