Results 1 to 3 of 3
Thread: Vs Calais Power Window Problem
    Vs Calais
    Apr 2009
    Default Vs Calais Power Window Problem
    Hi all. Wanting to know if anybody has had a problem with there power windows getting stuck in a vs. I have been able to get it to go back up using some WD-40 on some of the joints but it makes a real loud clicking noise when it reaches the top. Could any1 help? thanks
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Sound like a broken regulator or window motor gear stipped, maybe replace the regulator and motor!
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Have you checked to see that the four rivets that fasten the regulator to the door frame are still there and not loose. The standard rivets are aluminium and do break when they get older.
  1. power window problem
    By VNexecutive in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2010, 12:57 AM
  2. Power window problem...
    By Cyph3r in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-02-2009, 03:11 PM
  3. VT power window problem
    By joebloggs in forum Electrical Wiring / Questions
    Last Post: 21-02-2008, 07:34 PM
  4. VY Power Window problem?? - HELP!!
    By Fester1548 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-12-2006, 09:17 AM
  5. help! power window problem!
    By skarekrow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2004, 06:22 PM
