Results 1 to 5 of 5
Thread: VS commodore problem starting
    Vs Equipe
    Oct 2006
    Default VS commodore problem starting
    Hey all i have a vs commodore and i have a problem with my car starting. The car has done about 210k the engine and gearbox have done 62k i have a aftermarket alarm and 3 point imobiliser installed. Original key is being used. car was serviced about 3 weeks ago. ignition cables are about 6 months old. New Deep cycle battery (4months)
    the car has a problem starting when i turn the key after the immobiliser is disengaged nothing happens the dash is active lighing up but nothing happens engine wont kick over no starter or anything , i activate the alarm and disengage 1 or 2 times and it will start up fine im not really sure what it is. the dash is visually showing any faults , i guess the situation is somthing prevents the car from starting but when that fixes itself the car starts perfectly fine. Any got any ideas ? ? ? ? ? ? ? thanks in advance
    Fuel pump ????????
    %#$@%^#$^ key ????????
    key Barrel ???????????????
    coil packs ?????????????????
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Lightbulb Maybe!!!!
    Try a fault check first-
    Checking error codes VR/VS (Revised)
    But maybe it's the sensor on your key not touching your ignition it happens to mine every once in a while just push the key in a bit more when turning it over!!
    Vs Equipe
    Oct 2006
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by tiersum View Post
    the engine light isnt on so does that mean its error free ?
    Not necessarily, best to check the codes to see if there are any.
    MY RIDE
    vs commodore
    May 2009
    it will be our security, turn key hit unlock button then turn over again, need to get security check
  1. VN starting problem
    By wes_v8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2009, 04:58 PM
  2. vx commodore starting problem
    By babo natale in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-04-2009, 02:18 PM
  3. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  4. VP Commodore Starting Problem
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2006, 02:19 AM
  5. VP Starting Problem
    By brad_m_is in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2006, 10:11 AM
