Results 1 to 11 of 11
Thread: Handbrake Bang
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Default Handbrake Bang
    I have been into the handbrake assembly so many times and readjusted everything and spray the springs and it still makes this noise.
    Sometimes it works for a bit then comes back...
    When I take off I get a bang noise coming from the rear. Turning corners and stop starting still makes the noise. I know it's the hand brake because when I drive along and apply it I get the bang.
    Are the shoes moving and slapping around or something?
    Handbrake works good...But this banging noise really shits me to tears after so many times ripping the rotors off and trying to find the problem.
    The shoes still look to have a fair bit of meat left on them and everything looks to be good so I'm stuck with idea's!
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    do you use your handbrake during take off ? I don't think the noise is coming from the handbrake. It could be something loose in the rear suspension.
    Chirpstr's Avatar
    Sep 2007
    Deferentially not the suspension. Every part of the suspension has been replaced and checked.
    VR HSV Clubsport
    Jun 2008
    Hobart,TAS
    Quote Originally Posted by Wavez View Post
    I feel your pain,having exactly the same issue with my car....sorta a cyclic knock noise.....donk..donk..donk..donk....thought it might have been the diff bearings so i changed them when i put the 3.45s and spool in,but its still there.......passenger side on mine.....i just gave up trying to fix it in the end....i got better speakers.
    Tasmania....Coz 2 heads are better than one...
    Chirpstr's Avatar
    Sep 2007
    Quote Originally Posted by Tas_HSV View Post
    LOL...better speakers would fix it.
    Doesn't sound good though hey? I'm really stuck with this, and sounds to be you are too.
    VR HSV Clubsport
    Jun 2008
    Hobart,TAS
    Can be sorta fun pullin your handbrake on a little going past cyclists.....BANG lol
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    probably find they are worn down to far or wrongly adjusted mine used to do the same thing till i put new shoes in and adjusted them properly its just the shoes jumping around on the pivot
    jakewaze's Avatar
    jakewaze is offline Jakewaze
    VN Spack S1 Auto
    Nov 2008
    Chirpstr's Avatar
    Sep 2007
    I think it's ok for now. I haven't had the bang for awhile, maybe they settled in fully after I adjusted it...If worse comes to worse I will put new shoes in there like delcowizzid suggested. Touch wood all is good!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Drum brake shoe linings can get glazed which may result in the shoe 'sticking' to the drum....this may be causing your 'bang'. The fix is to sand the shoe lining with coarse sandpaper to roughen the surface.....also use a file to file back the leading edge of each shoe as this also cuts down on noise. I had similar problems back in the 60's when I had a FJ with drum brakes the size of shoe polish tins all round - they would grab in wet weather and then fail to let go.
    Chirpstr's Avatar
    Sep 2007
    Cheers hako, will give that a try if the noise comes back...
  1. How to get this nut off!!!! :bang:
    By mischa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2009, 01:05 PM
  2. ive had it with my vp :bang:
    By rob drag racer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-10-2008, 08:34 PM
  3. ARRRRRH! HELP loud bang bang bang noise
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 10:58 PM
  4. Handbrake goes bang...
    By BottFodder in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-05-2006, 04:30 PM
  5. Bang :(
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2006, 06:14 PM
