Results 1 to 10 of 10
Thread: VR Berlina CLuster in Exec???
    Chris_vr's Avatar
    Chris_vr is offline HVY-MTL
    VR Executive
    Feb 2009
    Default VR Berlina CLuster in Exec???
    Hey guys! I pulled out the cluster and dash from my write off Berlina and want to put it into my Exec (same model) so that I can have the trip computer and all the rest!
    Can I just put it straight in and connect the wires and thats all???
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Yes but the trip computer part won't work you need the extra wiring loom and control panel for it to work properly.
    http://forums.justcommodores.com.au/...ion&sa=Go#1074
    http://cgi.ebay.com.au/ws/eBayISAPI....m=170320553503
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Yes but you'll need the dash loom out of your berlina too. It has 1 extra plug for the trip computers and for the buttons
    Reaper
    Chris_vr's Avatar
    VR Executive
    Feb 2009
    Can I just modify the existing loom? My Berlina loom suffered some damage :P
    And is the mod JUST for the trip computer or other stuff!
    IE: Do I need to connect new wires to the trip computer or to the cluster also?
    VrWagz1's Avatar
    May 2008
    wollongong
    theres a thread somwhere it shows extactly what you need to do, ill do a quick search. You basically just need the 4th plug, so cut that out as best you can and wire it into the exec loom.
    here..Tripin'... see post 18
    Reaper
    Chris_vr's Avatar
    VR Executive
    Feb 2009
    cool cool! Well I am a bit confused by the thread. DOes the exec loom NOT have the cable that goes into the trip computer itself?? And does it also not have connector 4 on the cluster???
    These are my main questions!@
    Sorry to be a pain!
    VX Calais
    Jun 2008
    SA
    no, the executive loom won't have the necessary connector to run the trip computer functions...
    you will need to cut out the 4th plug and wiring for the trip computer and tap these wires (9 in total) into the executive loom.
    the berlina loom won't work properly in the executive unless you change over to the higher level bcm and install climate control as there is no provision for a/c in the berlina's dash loom
    VrWagz1's Avatar
    May 2008
    wollongong
    The 4th plug we speak of is the odd plug out you will see when you pull the cluster out. Its the skinny one underneath on the bottom right hand corner when your looking at the cluster from the front. The other 3 are the standard 3 that are in the back of it.(also note with them when you pull em out which way they sit as they can go in right way up or upside down too)
    Reaper
    Chris_vr's Avatar
    VR Executive
    Feb 2009
    Yeah, when I pulled the cluster out of the Berlina I see it there, so I guess I need to use that for splicing as the exec one has the black plug 4. And then I make the additions for the trip computer yeah :P??
    SOrry once again, just trying to get my head around it
    Chris_vr's Avatar
    VR Executive
    Feb 2009
    Ok! All good, I've looked over it like fitty times and now I get it :P
    I'm quite good with a soldering iron, getting the loom out to do it though is going to be fun :S
    Cheers for the help guys!
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. HSV instrument cluster into VT Exec.
    By cybermatic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-05-2010, 02:57 PM
  3. level 3 cluster into vs exec??.
    By dylanfh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2008, 06:45 PM
  4. calais cluster in a exec?
    By jezzaaa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2006, 12:37 AM
  5. vn s-pac cluster on vn exec
    By keatz_RedVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-10-2004, 03:03 PM
