Results 1 to 16 of 16
Thread: rb30 into a VR/VS
    NO CAR ATM.. -.-
    Jul 2006
    Default rb30 into a VR/VS
    i know vn_luke put a rb30 in hes vn but i was wondering if its legal for a vr/vs??? for me to get a rwc for it in victoria na rb30 too.. but turbo it after rwc
    cheerss guys
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I think your only aloud to do it in VN's becuase they came out in 1988 with the VL's. if you do it with a VR/VS it won't pass emissions as it is a later car with an earlier engine (HAS TO BE AN EARLIER CAR WITH LATER EMISSIONS IE: NEWER ENGINE NOT OLDER), i think!!!!
    VP Executive R-spec
    Jan 2005
    It is legal, VR's run the same emissions ADR. A friend of mine is putting an RB30 into a VR ute very soon now. 1997 is when things changed. ADR 37/00 Runs from the start of unleaded in 1986 to 1997, you can interchange any engine in that range of years as they all passed the same test. From 1997 -2003 is ADR 37/01 from 2003-2007 ADR 79/00, then from 2007- ADR 79/01.
    You can put anything from the ADR the car came with in or anthing newer in. But you can not put say a motor From the 80s that was ADR 27a 27b or 27c in
    NO CAR ATM.. -.-
    Jul 2006
    vr ute
    Jul 2009
    Quote Originally Posted by greenfoam View Post
    thats me
    VS executive
    Jun 2009
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    the japanese 3.0 is pretty tough, but I would only do it with the turbo as well, I dont see the point if its NA unless you're a real fan of the motor.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    Quote Originally Posted by pillzor View Post
    whats the benefit of an rb30 over a 3.8 ? , just curious.
    It's a tested and proven motor that can make & handle decent power without heaps of money spent. - plus there is great aftermarket support and plenty of off the shelf go-fast bits available.
    VS executive
    Jun 2009
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    i would have said the same thing about the buick though.
    how many 10 sec/300kw+ rb30 powered VL's are there?
    and how many 10sec/300kw+ buick v6 powered VN+?
    The v6 development is getting there, though - it seems to have come alive a little bit in the last few years.
    VS executive
    Jun 2009
    yeh how much lighter is the VL though. ( i honestly dont know, you guys are the experts )
    VP Executive R-spec
    Jan 2005
    A VL is about 50 kilos lighter. but the difference in weight will be partly made up by the VN being a much better shape
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Does that mean a VN is more aerodynamic than a VL ? I thought the VL would have a much smaller sihlouette than a VN .. but i'm just not up with those old beasts.
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    Quote Originally Posted by greenacc View Post
    it cuts through the air like a boat through water
  15. #15
    VS executive
    Jun 2009
  16. #16
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    why dont you put a buick in a VL and see what happens.
    been done before, stock for stock the n/a buick v6 makes more power & torque than the nissan 3 litre, so it goes a bit faster
    I wouldn't change a 3 ltr turbo motor for a buck v6 though... but that's just me
  1. Nissan RB30 V Holden RB30???
    By neatvl86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-01-2011, 01:08 AM
  2. Rb30?
    By Jethrow666 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-06-2008, 07:13 PM
  3. rb30 into vh
    By bec22 in forum General Discussion
    Last Post: 16-02-2008, 01:17 AM
  4. RB30 into the vh
    By vh-holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-10-2005, 05:52 PM
