Results 1 to 6 of 6
Thread: A/C on/off button stuck in on position
    VS Executive
    Apr 2009
    Default A/C on/off button stuck in on position
    I am a newbie on these forums so Hi everyone. Can somebody please help.
    I have a VS Executive and the A/c on/off button in stuck in the 'on' position - green light is continually on whilst ignition is on. I have had this fault for some time but it has not worried me because I have been turning it off and on via the A/c fan control slider. It all works fine via the slider.
    I would like to get at the A/c switch to fix it with the help of a friend (aircraft electrician) but we don't know how to get at the switch. Could somebody please help.
    06 VZ SVZ Wagon
    Apr 2006
    Central Coast, NSW
    you proably need a new switch, shouldnt be too much from the wreckers.
    to get to it, just above the dash cluster (speedo and gauges) their are 2 screws, undo these, then gently pry with a screw driver around the edges of the black plate the buttons are in, be carefull though the pins can be brittle because of their age.
    hope it helps.
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Brand new switch from Holden is about $20.
    As posted above, be careful when prying back the black instrument cluster surround... especially now its so old, the clips will be extremely brittle.... they were bad enough when the things were brand new!
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Try not to use a screwdriver to lever out the bezzel as it will leave little marks. Try just grabbing around where all your red lights are below the speedo and pulling out there with your hands and you should be able to get it started. Takes 2 min to pull it out. As said just take it steady with it, no sudden jerks as you may break the little clips on the back which isnt the end of the world but can be a pain. To get the a/c switch out just squeeze the clips at the side of it and the whole switch slides forward and out the front of the bezzel.
    Reaper
    VS Executive
    Apr 2009
    Thanks heaps fellas for your excellent help. Will try to follow your instructions implicitly and will let you know how I/we got on. This is a fantastic forum - great for old retirees like myself who have no real mechanical experience. I will save a lot of money too.
    bfc
    bfc is offline
    Oct 2004
    wouldnt worry about it.....mine has trouble turning ON but when it does i leave it on all the time anyway...it wont hurt
  1. Vs a/c button stuck in 'on' position
    By donf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-04-2009, 06:42 PM
  2. New position available *****
    By TappetHead in forum Yella Terra
    Last Post: 21-08-2008, 08:16 PM
  3. WTB: VS speaker pods, Air con button, demister button
    By TA 91 WA in forum Swap / Wanted to Buy / Trade
    Last Post: 14-08-2008, 11:17 PM
  4. cassette button stuck in
    By kaycee in forum Car Audio
    Last Post: 28-12-2005, 01:10 PM
  5. Sub Position
    By TigerVX in forum Car Audio
    Last Post: 08-11-2005, 09:45 PM
