Results 1 to 2 of 2
Thread: Removing Ignition Barrell
    vs series II equipe
    Sep 2005
    Default Removing Ignition Barrell
    I have recently found that the key won't turn when you try to start the car. From the other postings it seems that you need to have the key in the 'on' position to remove the barrell. Can anybody shed some light on how to remove if I can't turn the key. I have tried using WD-40 to lubricate and still no luck. Thanks for your help in advance.
    vs series II equipe
    Sep 2005
    All good...found the sheer screw and used a chisel to remove bracket from column. Cheers anyway.
  1. Removing VN Ignition Barrel
    By troy_crees in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2009, 02:34 PM
  2. Ignition Barrell - how do I get it out?
    By VPBOY in forum General
    Last Post: 26-03-2007, 07:51 PM
  3. Removing Ignition Barrel
    By mischf in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2007, 09:21 AM
  4. Ignition barrell HELP
    By BOGANV8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-11-2006, 07:19 PM
  5. Ignition Barrell
    By jonathon_86 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-01-2006, 08:59 AM
