Results 1 to 7 of 7
Thread: humming at idle
    vr berlina
    Aug 2008
    Default humming at idle
    sometimes when at idle my car has a slight humming that i can hear coming from the front of the car and not sure what it could be?
    93 VR Executive Wagon
    Mar 2009
    Melbourne, Bentleigh East
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    radiator fan
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Probably a rough bearing in one of the serpentine belt pulleys - remove the belt and spin pulleys by hand. If they fail completely the car will stop.
    Good Luck.
    vr berlina
    Aug 2008
    could this cause the car to cut out for a second but turn back on automatically straight away coz my car did this yesterday? didnt even have to touch ignition or pedals or anything, just went out and then straight back on
    Turbo VS II 5 Speed
    Jan 2006
    Hong Kong / Adelaide
    Quote Originally Posted by hako View Post
    Good Luck.
    The other thing you can do if your CAREFUL is to take a long flat-head screwdriver, place the head on the bolt of the pulley and your ear on the "butt". You can hear the difference between a shagged bearing and a good one.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by vpcommo View Post
    Can't see how it would - the reason your car stops if a pulley bearing fails is that it throws the fanbelt off and you lose your waterpump and the car will boil very quickly - if you don't stop immediately you stand a good chance of seizing the engine. Re your miss I'd do a fault code check as your CAS may be failing and you are getting an early warning. "How to" is attached:
    Checking error codes VR/VS (Revised)
  1. humming noise
    By freshh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2008, 09:56 PM
  2. humming sound.
    By filmur77 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-04-2007, 01:23 PM
  3. humming noise
    By fatty in forum Car Audio
    Last Post: 30-04-2005, 02:14 PM
  4. Humming Noise coming from speakers
    By RichardW in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-03-2005, 01:25 AM
  5. Humming Noise coming from speakers
    By RichardW in forum Car Audio
    Last Post: 05-12-2004, 10:33 AM
