Results 1 to 23 of 23
Thread: Vr vs boot strut difference
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Default Vr vs boot strut difference
    Right the problem is I`ve got my missus car that has an after market sploiler
    the struts are clapped and I need another set, there are two types the non spoiler and spoiler type the spoiler type is for factory fitted spoilers, so my question really is ..whats the difference, mounting points, more weight from the spoiler = needing bigger struts or what?, the ads on ebay are vauge at best...help please.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    pay for postage and i will send you a good pair from a vs boot with a spoiler
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Zuicider knows what the is talking about - the boot and spoiler need a heavier strut and sellers usually ask if the boot has a spoiler.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    To look at there is no physical difference between standard struts and struts to suit a spoiler and they both fit the same way. The struts to suit the boot with a spoiler just have a higher compressive pressure to compensate for the added weight of the spoiler.
    VS Stato SII L67 S/C V6
    Apr 2004
    Heres the tech data -
    So struts are rated by the amount of energy in Newtons they can push.
    Standard VR/VS boot strut = 460 Newton pressure
    VR/VS Stato/Commo + Wings/Spoilers = 530-550 Newton pressure
    The geniune units are made by Lift-o-Mat, and the newton rating is printed on the struts at the bottom of the blurb. i.e. 460N will be printed in larger letters than the rest.
    If the strut is a lower newton than required, it wont push up the extra weight.
    The strut re-gas mobs will make them whatever pressure you want, will cost around 66 for the pair.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by haloeight View Post
    Thats good tech data haloeight, I've always wondered how you could tell how much force struts have, now I know.
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    VN Group A Replica
    Oct 2011
    Perth Australia
    Default hey
    Quote Originally Posted by undar8ed1 View Post
    hey just wondering if you have any pictures of the gas struts in the VR/VS Sedan ... Just as i am trying to convert my VN so it has gas struts
    Apr 2004
    Can we get this thread made a sticky? That info isn't easy to find!
    I'll also add that you need to install the struts in a way so that the seal at the top of the piston shaft is facing down, as they are lubricated by oil inside the body of the strut. If you install them the other eway, the seal will dry out, causing the gas to escape and stuffing up the strut.
    Finally, if you get a re-gas on the struts and ask the regasser to do them, say 15-20 newtons higher than spec, you should get the boot to automatically pop up when you press the release.
    I'll have a photo of the strut assembly when I can get it off my phone.
    Apr 2004
    1990 VN Executive
    Nov 2005
    Quote Originally Posted by andrewcutter212 View Post
    I tried doing this to my VN using VR VS struts but mounted differently.....But when the boot opened it opened with so much force the boot nearly ending up on the bonnet.....
    Tried with just one strut but boot opened crooked
    Could work but would need to get custom struts made up with less power
    Having said that, now that I have replaced the oem VN springs it still opens with quite abit of force..
    Dazz
    VN BT1 Mock Up Commodore
    Dynamic Locksmiths
    VN Group A Replica
    Oct 2011
    Perth Australia
    okay thanks guys.. cause i have tried installing them and i have got the right gas struts.. and i have put them in but when i close the boot lid... .. the boot right near the rear windscreen is raised.. so their for is not sealed.... and u have got quite a big gap.. sooo i am really out of ideas LOL ... thats why i really need some he
    VN Group A Replica
    Oct 2011
    Perth Australia
    also if any1 has pictures of where they have mounted it in their vn boot that would be great as that would give me a more detailed information in regards to where i have to mount them properly ay
    Brendo169's Avatar
    Brendo169 is offline HSV Porn
    VS Senator
    Aug 2009
    WA
    my old clubsport hasd the wing replaced by an s pac boot lip
    the lower weight of the small lip made my boot open so easy.
    id pull the lever and it would open right up all on its on...was awesome!!
  15. #15
    VB SL/E
    Dec 2008
    Yeah Awesome till they start ripping the bracket off from under the parcel shelf.
  16. #16
    VN Group A Replica
    Oct 2011
    Perth Australia
    where abouts did u have them mounted in the vn... that u have... cause i have vs spoilered gas struts.. not to sure where to mount them.. soo do you have a picture dazz in which could indicate to me where i should mount them.. Please get back to me thanks mate!
  17. #17
    1990 VN Executive
    Nov 2005
    bear with me
    Dynamic Locksmiths
  18. #18
    1990 VN Executive
    Nov 2005
  19. #19
    VN Group A Replica
    Oct 2011
    Perth Australia
    hey dazz did u you have a problem with... the boot been raised up near the rear windscreen.. cause i have this problem when closing the boot.... any ideas on what i should do.. Get back to me mate.. thanks alot hay
  20. #20
    1990 VN Executive
    Nov 2005
    yep sure did, hence why I gave up and got hold of the original boot springs...........From what I understand where I located it, is the same spot as the VN Group A's but obviously there boot lid is a lot heavier because of the large spoiler...
    Dazz
    Dynamic Locksmiths
  21. #21
    VN Group A Replica
    Oct 2011
    Perth Australia
    lol i got the original VN group a spoiler lol .. soo imsoo confused lol i mounted it in the same place.. but yer far out man this is soo fricken confusing LOL damn it cause its still raised LOL .. i dont no what the hell could be diffrent.. any ideas ?
  22. #22
    1990 VN Executive
    Nov 2005
    Really need a pic of inside a group A boot
    Dynamic Locksmiths
  23. #23
    VN Group A Replica
    Oct 2011
    Perth Australia
    can any1 help?
  1. [SA] May Trade: VR Boot with SS Spoiler, for stocko boot.
    By StockoVRWagz in forum Swap / Wanted to Buy / Trade
    Last Post: 04-04-2009, 04:07 PM
  2. Strut Brace - Makes a difference
    By Avi8or in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-03-2008, 09:23 PM
  3. boot strut bracket broken!
    By vsdore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2008, 11:28 AM
  4. boot light stays on when boot is closed
    By seans VL Calais in forum Electrical Wiring / Questions
    Last Post: 25-09-2007, 05:17 PM
  5. Broken boot lid gas strut mount
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2006, 09:30 AM
