Results 1 to 3 of 3
Thread: No Grunt When Cold
    VR Executive
    Mar 2009
    Default No Grunt When Cold
    Hi All,
    I have a 94 VR, and when the car is first started in the morning and the Engine Temp Gauage is on 0, I have no power in first gear. I go to 3000 rpm's real quick (without putting my foot down very hard) and about 15kmph. The finally it goes into second gear and I get a little bit more power, but not as much as when the car is warmed up.
    To compare, when the engine Temp Gauage is at 1/8 or 1/2, the car performs great. I get quick take off's and the taco does't race to 3000 rpms. The car sounds great and all is sweet.
    I have no errors codes on my computer. The car history is a bit unkown as I only bought it about 18 months ago. I have recently replaced the Alternator (8 months) and O2 Sensor (3 weeks).
    Any Help/Suggestions would be greatly appreciated, but keep in mind I don't know a heap about engines.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Your auto transmission may need servicing as this problem can occur with worn cjutches/bands and or a blocked filter in the trans. Also check the trans fluid level and the colour - it should be pink or reddish - brown indicates the trans is pretty worn.
    If you have the owners manual it will show how to check the fluid level - it's also on the dipstick. Good Luck.
    vs wagon
    Jan 2009
    darwin
    Default no power
    has the vaccum hosse dropped from your map sensor or manifold this will give these symptoms
  1. LOw End grunt
    By esp22 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2008, 10:43 PM
  2. V6 need more grunt!
    By wicked05 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-03-2008, 01:24 PM
  3. Grunt
    By Rombles in forum VY - VZ - WK - WL - V2
    Last Post: 25-02-2007, 06:45 PM
  4. more grunt
    By internalkaos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-07-2005, 01:25 PM
  5. A Little More Grunt
    By dellarb in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-03-2004, 10:49 PM
