Results 1 to 5 of 5
Thread: VS SS headlights dim whilst driving
    VS SS
    Dec 2008
    Default VS SS headlights dim whilst driving
    hi all, i need help as i dont want to buy a new alternator if not required, lately when driving with lights on ( not high beams) the headlights dim and then will regain full brightness and then dim again, i have noticed its intermittent. also i dont know if this helps but the battery light also appears intermittently aswell. the battery is new and i never have issues starting the car. Any ideas??
    VP SS
    Jan 2008
    Hiding in WA somewhere
    you need an alternator
    If its got Wheels or Boobs its gonna cost ya money
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Check the connector at the back of the alternator to make sure it isn't loose or has burnt (common fault). Failing that, it's a new alternator.
    VR/II 5L UTE
    Sep 2008
    st clair NSW
    i had the same thing with mine, changed regulator and checked alternator, turned out to be the connector at the battery for the fusable link had become coroded and was hardly connecting.
    This cable comes from the rear of the alternator to moniter the charge level, seeing as though it had no connection, the alternator thought the battery was charged and stopped working, then 2 minutes down the road my car would stall and id be pushing it out of harms way.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You can remove the brush pack from the rear of the alternator (2 screws) and check if the brushes are worn down - they cost less than $50 including the regulator....a lot cheaper than a new alternator. Worn brushes can cause the alternator to charge sometimes and when the worn brushes lose contact you get no charge...lights dim and the red charge light comes on. I'd get on to it soon before you start having battery problems with the cold weather coming.
    Good Luck.
  1. Ever had any close calls whilst driving?
    By Flat_White in forum The Pub
    Last Post: 22-08-2008, 04:41 AM
  2. ticking noise whilst driving
    By bigg_vin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-01-2007, 09:47 PM
  3. VP losing power whilst driving
    By mbvp73 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 01:07 PM
  4. VX Commodore stalling whilst driving!!!
    By chipper_222 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-03-2006, 12:47 PM
  5. Engine cuts whilst driving.
    By BR377 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2005, 02:59 PM
