Results 1 to 8 of 8
Thread: VR Fuel Pressure Readings
    VR Calais
    Mar 2009
    Default VR Fuel Pressure Readings
    heyy all
    just wondering if anyone knows what the fuel pressure reading should be for VR Calais
    any info would be great thanx
    smarty091..
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    a quick search would have bought up this thread: VS fuel pressure which wasnt too long ago has the pressure readings in there.
    do you suspect yours is lower than what it should be?
    VR Calais
    Mar 2009
    Quote Originally Posted by ephect View Post
    yehh i did a pressure test on my car today and got 35Psi not sure if thats ok at idle. when i blocked the return line and it went up to about 60psi.
    it has a misfire underload. changed plugs leads coil pack DFI module and injectors and is still there thinking it might be fuel pressure regulator???
    you have any ideas.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    nup that pressure is fine, 235-245kpa is the range, and 35psi is roughly 240kpa so its within the range.
    have you done an error code check? to see if there are any codes logged?
    VR Calais
    Mar 2009
    yeh checked that no faults codes were logged.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    sorry the range is
    idle = 240-260kpa
    engine off = 280-320kpa
    urs is at the bottom of the range, you could change the fuel pressure reg, you've changed the normal parts that cause this problem.
    hows ur injectors? recently been cleaned or replaced?
    VR Calais
    Mar 2009
    sorry the range is
    idle = 240-260kpa
    yehh replaced injectors already might try fuel reg see what happens.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    the ideal pressure with no vacuum should be 43.5psi (thats what the injectors are rated at) so the 280-320kpa or 40.5-46psi range is correct, although i think the range is a bit to wide personally. to check simply remove the vacuum hose(from the regulator) when the engine is running
    the above mentioned pressures are correct from VN to VS. from VT onwards they increased the pressure on the injectors for 3bar to 3.5bar(50psi)
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. High Fuel Pressure - Bad Fuel Economy?
    By Goldie87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2011, 11:23 AM
  2. VS fuel pressure
    By aceventura in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-04-2009, 09:59 PM
  3. Fuel Pressure Regulator - Poor fuel consumtion
    By Chuckster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2008, 03:49 PM
  4. level 3 dash help fuel readings
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2007, 05:56 PM
  5. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
