Results 1 to 5 of 5
Thread: VR running rough
    VR Calais
    Mar 2009
    Default VR running rough
    ok well got a VR Calais when i drive it in the mornings it runs ok only has a little bit of a misfire. when it gets hot it gets worse.
    i have changed Plugs, leads, coil pack, DFI module, injectors.
    not sure if it could be fuel pressure regulator??
    anyone got any ideas???
    vr calais
    Apr 2009
    brisbane
    one item that gets over looked is your map sensor vacum line..mine had a crack in the line ran rough heaps of black smoke out exhaust but engine light didn,t come on,changed the rubber line and ran great
    VR Calais
    Mar 2009
    Quote Originally Posted by kingrat502 View Post
    where abouts would i find this vacumm line??
    vr calais
    Apr 2009
    brisbane
    best way is on the firewall you find a map sensor ,passenger side,follow where the hose goes,,,,they are like a small rubber line but go hard and brittle with the heat,,
    VR Calais
    Mar 2009
    ok thanx alot ill check tomorow see how it goes.
  1. Vn - Rough start & Rough Running Below 2k
    By ghog1726 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2009, 10:02 PM
  2. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  3. VN running rough
    By modcon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2006, 08:26 AM
  4. VR ute running rough
    By FREESTYLE_MX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2006, 11:56 PM
  5. running rough
    By Rumbl in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2005, 05:24 PM
