Results 1 to 10 of 10
Thread: rack end removal
    vr commodore
    May 2008
    Question rack end removal
    Hi all, is it possible to replace the power steering rack ends on a vr without removing the whole rack???????
    jace123's Avatar
    jace123 is offline jckoolio
    3.8 94 VR Executive
    Mar 2009
    gold coast
    good question... i don't think so. i just removed mine... if there is a way i didn't see it
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    any one replaced their rack ends recently? im due for mine soon, well parts are on order and next week i'll be attempting this.
    can this be done on the car? tips tricks, my elleries manual doesnt list replacing the rack ends, only tie rods (which im doing also).
    do you need a tool at all for removing the rack ends?
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    yeah, a large shifter and a pair of vice grips... steady the rack and unscrew the ends...
    aZk.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    lol sweet thanks azk
    HSV VZ Maloo Ute TT
    May 2009
    Near Adelaide
    If you are talking about the tie rod ends that connect to the wheel hub, then yes they can be replaced. Simply use a shifter (not best tool) and crack the nuts that are behind the actual tie rod ends so that it is not secure against the tie rod end anymore. Once the nut on both sides have been loosened un-do the nuts holding the tie rod end to the stub and remove tie rod end.
    May 2005
    .....SE Burbs
    The rack ends, which go from the rack to the tie rod ends are easy as... they just screw in!
    There is a lock washer, you need to bend the pins out before you can crack the thread, you'll need new ones. But yeah, after you bend the lock washer pins out, steady the rack then undo the rack ends, make sure you dont put to much pressure on the ps rack at any time.
    Try to have as little of the spline out of the rack as you work on each end.
    There is no special tool for this...
    aZk.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    so the rack ends arent actually the steering rack ends, its just the 'tierod part' that screws into the end of the rack. makes more sense, i had thought it was part of the steering rack itself. happy days
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Make sure you mark the tierod ends so you know where to screw it back on to!!!
    They can be mongrels to get out... I would advise you to get a ball joint remover.
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Rack ends... I need to do this. Got 1 new tie rod end in already, other one is fine but will replace anyway.. but rack ends have got play and steering knocks around on rough ground.... Any tips for young players on where's the best place to get em / good brand etc? Or just grab whatever I can find?
    WTB: mulberry VN interior parts
  1. [QLD] WTB: Steering rack for VT/VX V6
    By Steven M in forum Swap / Wanted to Buy / Trade
    Last Post: 03-01-2009, 05:07 PM
  2. vs p/s rack
    By big m in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-06-2008, 08:51 PM
  3. steering rack
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2007, 04:03 PM
  4. Amp Rack in my VT
    By littlejon in forum Car Audio
    Last Post: 26-09-2006, 02:25 AM
  5. Rack End?
    By riewoldt12 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2005, 10:36 AM
